Bronco II Ford Bronco II
2.8-2.9
Old Oct 27, 2003 | 01:33 AM
mikepn's Avatar
mikepn
I have a 84 bronco 2 with the 2.8,the gutless wonder.I have a chance to buy a new 86 2.9 long block.Are these two engines interchangable or what.I know nothing about these motors.
Old Oct 27, 2003 | 04:03 AM
frachubb's Avatar
frachubb
your orginal tranny should bolt up just fine along with the engine mounts. things to keep in mind though is that your moving from carb to EFI. So make sure you have all the accesories needed. I have a 84 Bronco II 2.8L my self and my bronco has all the 2.9L wiring in the event i swap to the 2.9. You might want to see if you have a friend that has a 2.9L bronco II and compare UNDER THE HOOD wiring just to be in the safe side. Good luck Brother Bronco II!
