Engine sputters but does not fire
Old Feb 23, 2021 | 07:54 PM
Hackettbr1's Avatar
Hackettbr1
Hello,
I have an 86 f250 w/ 460 4speed manual, I recently replaced the ICM do to a crank no start. The truck moved about 100 feet before the rpm began jumping all over the place and then the engine died. I haven't had a lot of time to diagnose anything major, the bowl has fuel and is spraying into the intake, timing was good before I replaced the ICM. other than that I have absolutely no idea whats going on.
Old Feb 24, 2021 | 12:13 PM
ctubutis's Avatar
ctubutis
It seems to me that either 1) The ICM isn't the problem, or 2) It's faulty. I'd put the other one back and begin again.
Old Feb 24, 2021 | 12:31 PM
Hackettbr1's Avatar
Hackettbr1
The factory icm was dead, no spark from any of the plugs until it was replaced with an oem variant.
Old Feb 24, 2021 | 02:06 PM
Max Capacity's Avatar
Max Capacity
FWIW, I learned years ago with something this old, bite the bullet and buy a rebuilt distributor. Cost me a lot to learn that lesson. I could have saved a couple hundred if I had just done that to begin with. After the new ICM was installed, the coil went and took the ICM with it. A rebuilt unit lasted many years.
Old Feb 24, 2021 | 10:58 PM
Hackettbr1's Avatar
Hackettbr1
I'll have to get one, though until I'm able to does anyone have any other suggestions?
Old Feb 25, 2021 | 07:44 AM
Max Capacity
Last summer I had to clean the contacts at the coil connector. My 302EFI kind of did the same thing.
Not sure how a 460 is wired but pull the connectors and make sure the terminals are clean.
Alexjordan22
Dec 28, 2015 09:49 PM
dragonslayerfx
Sep 11, 2007 08:56 PM
Boss50
Jan 18, 2004 09:14 AM
fasch74
Dec 2, 2003 12:23 AM
leadmic
Jun 23, 2002 09:38 PM
