valve noise
Old Feb 23, 2021 | 05:50 PM
lowrider50's Avatar
lowrider50
valve noise
Ibought a 95 f-350 5.8 motor. I noticed a lot of valve noise at the time.. The push rods are 7.521 long. I have seen that the right length is 7.567.I havent been able to find even a listing for this length . Hoping somebody on here knows where they are available
Old Feb 24, 2021 | 07:53 AM
ViperGreg's Avatar
ViperGreg
They should be available from any place like Crane Cams, Comp Cams, etc.
Old Feb 24, 2021 | 10:16 AM
lowrider50's Avatar
lowrider50
I tried them I even tried parts manufacturers, they don"t even list that size.
Old Feb 24, 2021 | 03:45 PM
torq'ta 5 8's Avatar
torq'ta 5 8
which length are you trying to go back with, because If you have pedestal mount rocker arms. push rod is 7.567", using stock heads that have not been surfaced, or the block hasnt been decked. If you dont know what, previous owner(PO) has done, then if I were you, I would check to be sure. jus cause.
Old Feb 26, 2021 | 12:15 PM
lowrider50's Avatar
lowrider50
Yes I needed 7.567. the p.o. had 7.521. I located a set on ebay.
66 bronco roadster
Apr 13, 2019 08:32 PM
javi2001
Dec 11, 2004 08:55 PM
