Sponsored by: Real Truck
Dual Battery Conversion
Old Feb 23, 2021 | 08:28 AM
kc5hwb's Avatar
kc5hwb
Hey folks, been a while since I have posted here.
I have a 2004 F250 with the V10 Gas engine and I am looking to add a 2nd battery to the truck. A friend that I hunt with has a 2003 F250 with the Diesel engine (truck body style is nearly the same) and he has dual batteries in his factory setup. He has a battery on both sides of the engine well, while mine is just on the passenger side. Given this fact, I thought there might be a conversion kit or some kind of simple steps to add a 2nd battery to my '04 F250.
Any help is appreciated, thanks much!
Old Feb 23, 2021 | 09:41 AM
redford's Avatar
redford
FTE Leadership Emeritus
I've never seen a kit.. Most owners just rig up a generic battery tray where it can fit and tie the second battery into the electrical system. I've also seen marine battery cases mounted on the frame rail below the cab. This mounting approach lends itself to a dedicated RV battery if an isolator is used.
Old Feb 23, 2021 | 10:00 PM
kc5hwb's Avatar
kc5hwb
Someone else had linked a kit in a post I found in a search - someone selling them on ebay. But I contacted that seller and those are only for 2011 and newer models.
Mounting on the frame rail is an interesting idea. I do want to run it on an isolator and use it for some Radios and Overlanding gear. It might actually be easier to power those things if the battery is closer to the bed. I will have to look at that.
Old Feb 24, 2021 | 09:02 AM
crusty old shellback's Avatar
There was a member on here who did a dual battery set up on his V10.
I can't find the thread though.
But he moved the canister down some and installed a factory battery tray and used the factory wiring harness. Looked like a clean set up.
Here you go, I found the thread. This should help you out.
https://www.ford-trucks.com/forums/1...-8-trucks.html
Old Feb 24, 2021 | 09:58 AM
Just noticed you want to run an isolator to run radios etc.
I did a similar setup in my K5 Blazer for off roading. Secondary battery was used to run the stereo, VHF race radio and off road lights. That way I could run it all without running the engine or killing the battery. Easiest setup I found and used was a blueseas relay. But you have to use the correct one.
I got one that no matter the condition of the secondary battery, once the motor was running, it would energize the charge relay and charge the secondary battery. Some of the ones they have, the secondary battery cant be lower than a certain voltage level or it will not energize to charge. I think it was like 11 volts or somewhere around there. That didn't work for my application as a few times, the secondary battery was below that threshold.
Old Feb 28, 2021 | 03:16 PM
kc5hwb's Avatar
kc5hwb
Thanks, this is kinda what I was looking for.
budawe
Oct 7, 2019 09:42 AM
DIYiT
Nov 2, 2010 01:50 AM
guerrero101
Jan 30, 2006 11:08 AM
70CamperSpecial
Apr 29, 2005 09:09 PM
rdavid
Oct 30, 2002 03:14 PM
