Transfer Case Potential Failure
Old Feb 22, 2021 | 07:52 PM
Zero_HedgerGaming's Avatar
Zero_HedgerGaming
Exclamation Transfer Case Potential Failure
Hey All,
I've had my truck for a month or so and one of my family members was driving it in 4wd during heavy weather going about 25mph. The truck was then moved into the parking space. For whatever reason put into N then 4L, then back into 2H without letting the truck roll at all to disengage/engage 2H. Now whenever the truck is shifted into a drive gear such as R or D there is a horrible grinding noise and has to be played with to even move. For now the Transfer Case manual selector is in the N position with the hubs now unlocked and the truck in park. Is the transfer case shot, or does it need to be toyed with until it grinds itself back into 4WD? It is a BW4407 with manual hubs and selector. Hoping to not have to replace the transfer case but I will have to if it is needed. Engine is a 460 V8 with an auto trans.
Old Feb 22, 2021 | 08:28 PM
cooksmtn's Avatar
cooksmtn
Sounds more like a linkage issue than bad xfer case. Shifting from N to 4L to 2H can be done with the truck sitting still, I do it regularly when moving my truck around the yard. If by heavy weather you mean the winter crap recently, maybe some icy slush is frozen up around the linkage, keeping it from fully engaging.
Old Feb 22, 2021 | 08:37 PM
Zero_HedgerGaming
Where would the linkage be located?
Old Feb 22, 2021 | 08:38 PM
Zero_HedgerGaming
also what if the shift happened when the vehicle was in park?
Old Feb 22, 2021 | 08:58 PM
cooksmtn's Avatar
cooksmtn
The lever you move near the transmission hump goes through the floorboards, and connects to the transfer case, visible by crawling under the truck.
The transmission will have no effect on what you do with the transfer case lever. the transfer case is strictly mechanical, unless you have a push button control.
Old Feb 22, 2021 | 10:41 PM
Zero_HedgerGaming
Alright man thanks for the help, should be getting it fixed soon. Hoping that its only the connection and not the case and its gears.
Old Feb 23, 2021 | 07:09 AM
My4Fordtrucks's Avatar
My4Fordtrucks
It sounds like the transfer case is between gears or the ( manual? ) hubs are not completely disengaged.
You can shift between 2H, 4H, N & 4L while stopped. There is no need for the truck to roll to come out of one gear and go into another.
Old Feb 23, 2021 | 09:16 AM
Zero_HedgerGaming
By manual I mean you have to get out to lock them, and I believe you are correct, it got stuck and we were able to put it back into 2H. Takin it to the shop this weekend to get linkage and fluid checked for any evidence of metal pieces.
DAVID'S97F250HD
Mar 7, 2024 08:04 PM
yachtonwheels
Oct 1, 2010 08:50 AM
Katmandu
Nov 19, 2008 08:38 PM
swamprat
Feb 16, 2006 05:21 PM
