High stall converter needed?
Old Feb 22, 2021 | 02:05 PM
rd65's Avatar
rd65
I have a 1980 F350 DRW that is under going some engine work. The engine will have 9 - 9.3:1 compression, C6, 4.10 gears, intake, headers, tires are 31.6" tall (says Discount tire site), 2wd. I am leaning towards a
Comp Cam Grind Number:XE262H
Engine Family:Ford 351C, 351M-400M 8 Cylinder (1970-1983)
RPM Operating Range:1,400-5,600
Cam Type:Hydraulic Flat Tappet
Lifter Style:Hydraulic Flat Tappet
Camshaft Series:Xtreme Energy
Camshaft Gear Attachment:1-Bolt
Usage:Street/Performance
Valve Springs Required:Yes
Camshaft Material:Cast Iron
California Proposition 65:WARNING: Cancer and Reproductive Harm P65Warnings.ca.gov
Advertised Intake Duration:262
Advertised Exhaust Duration:270
Intake Duration at .050 Inch Lift:218
Exhaust Duration at .050 Inch Lift:224
Intake Valve Lift:0.513
Exhaust Valve Lift:0.52
Lobe Separation:110
Assembly Lubricant Included:Yes
Intake Centerline:106
Lobe Lift Intake:0.298
Lobe Lift Exhaust:0.301
Summit says maybe a 2,000 stall converter, Comp says stock ok, machinist says I might want a converter.
What's the real answer, if there is one. Truck will do some light hauling, occasional heavier hauling, maybe some towing.
thanks for any help
bootless1075
Mar 11, 2020 08:02 AM
JTB321
Aug 30, 2017 12:05 PM
Kirbys73F100
Jul 16, 2010 09:25 AM
fiscus
Oct 30, 2003 07:30 PM
mustange70
Jun 13, 2002 12:48 AM
