AOD torque converter advice
Old Aug 29, 2017 | 12:30 PM
JTB321's Avatar
JTB321
Soon need to buy a torque converter for the AOD to match my engine and driving style. I know very little on the subject so please offer suggestions as to what worked for you with respect to stall speed. Engine is a 351w (+0.030), Edelbrock top end kit (2092) with about a 9:1 compression ratio. I have an 8.8" axle fitted with 3:73 gears. Driving is purely street cruising.
Thanks, John
Old Aug 29, 2017 | 01:02 PM
EBEAR's Avatar
EBEAR
Looks as its a fairly stout cam but with 373 gears and street driving I wouldn't go to much over stock . The higher the stall the more heat is generated . Do you know the rmp band of the cam-kit ?
Old Aug 29, 2017 | 01:29 PM
JTB321's Avatar
JTB321
I'll check the cam details later today and post what I find out.
Thanks
Old Aug 29, 2017 | 09:26 PM
JTB321's Avatar
JTB321
The cam is an Edelbrock Perfromer RPM.
Specifications:
-Duration at 0.006" Lift: Intake: 290?/Exhaust: 300?
-Duration at 0.050" Lift: Intake: 224?/Exhaust: 234?
-Lift at Cam: Intake: 0.310"/Exhaust: 0.325"
-Lift at Valve: Intake: 0.496"/Exhaust: 0.520"
-Intake: 6? BTDC/38? ABDC
-Exhaust: 51? BBDC/3? ATDC
-Centerlines: Lobe Separation - 110?/Intake Centerline - 106?
Old Aug 30, 2017 | 10:24 AM
56panelford's Avatar
56panelford
Curious if the lower end is pretty much stock other than the oversize..
Old Aug 30, 2017 | 12:05 PM
edzakory's Avatar
edzakory
I purchased my torque converter from Hughes. They have excellent support. Besides the info you provided, they want to know tire size. If you call them with the specs, they will suggest the proper converter.
It does not appear you are much over stock which would put you in the 1800- 2000 range. However, I would check with the experts to be sure.
Kirbys73F100
Jul 16, 2010 09:25 AM
reed1951
Oct 27, 2007 12:24 AM
umdstang
Mar 23, 2004 09:19 PM
fiscus
Oct 30, 2003 07:30 PM
mustange70
Jun 13, 2002 12:48 AM
