Windshield Adhesion Recall
Old Feb 22, 2021 | 09:44 AM
LMychajluk's Avatar
LMychajluk
2020-21 Ford Super Duty trucks built in Kentucky between Oct. 13, 2020, and Jan. 23, 2021
https://www.autoblog.com/2021/02/22/ford-truck-recalls/
I wonder if this would manifest as a rattling? I heard a rattle coming from what sounded like the glove box area yesterday. I couldn't pinpoint it or determine a cause, but it could've been a bit higher. My truck was built in the timeframe above.
Old Feb 22, 2021 | 10:27 AM
Kidder69's Avatar
Kidder69
Interesting, I've had the same rattle come and go in the upper glove box area, too. My truck was built 11/20.
Old Feb 22, 2021 | 10:43 AM
Grass Lake Ron's Avatar
Grass Lake Ron
A truly sticky situation since Ford hasn't built to many. Ford can't afford to be stuck with the cost right now.
Old Feb 22, 2021 | 10:55 AM
scraprat's Avatar
scraprat
Top Answer: 5
It will cost them some money but atleast it's not a fuel cell that can blow up. Small inconvenience to the owners of the trucks to get it reinstalled unless maybe you're in Alaska.
Old Feb 22, 2021 | 11:10 AM
pjsinAK's Avatar
pjsinAK
What about the payload recall?
moved to proper thread.
Old Feb 22, 2021 | 11:40 AM
GNR22's Avatar
GNR22
Greeeeeat. Both mine and my brother's '21s fall into this. Built in 11/20 and 12/20. I am going to be so unimpressed when my windshield starts leaking after they "fix" it. Hopefully they farm the job out to Safelite.
Old Feb 22, 2021 | 12:10 PM
4wd6.7L's Avatar
4wd6.7L
That's just the standard Super Duty glove box rattle 😆. But seriously, my 2019 has a rattle from the same glove box area. My wife thinks from the upper box, my son just points at the general area.
I windshield with failed adhesion can clap when hitting bumps if its a large enough section thats failed, but what is more likely would be air noise.
Old Feb 22, 2021 | 06:02 PM
LMychajluk's Avatar
LMychajluk
Originally Posted by 4wd6.7L
That's just the standard Super Duty glove box rattle 😆....
Well, as long as it's 'standard', then I guess it's not a problem.
Old Feb 22, 2021 | 06:50 PM
KU4OJ's Avatar
KU4OJ
I wonder if that accounts for a number of wet floors?
Old Feb 22, 2021 | 06:54 PM
Germanrazor's Avatar
Germanrazor
Mine falls into this boondoggle too!
Old Feb 22, 2021 | 07:26 PM
Ding126's Avatar
Ding126
So disappointing to see that there's an issue with the windshields.
The glass seems cheaper, thinner these days and now they cant get the sealant correctly...Is this a robot or a union worker who installed the adhesive? Makes me wonder.
I would be pissed....Some of these window replacement companies, which ford will use in many areas..do more damage removing the existing glass..Scratching the paint the paint finish under the glass and 99% of them wont re paint the scratched up areas, Glass chips in the dash vents.
I feel for ya'll
Old Feb 22, 2021 | 07:44 PM
Antoniodef's Avatar
Antoniodef
Scratching paint on windshield removal mainly comes from a tool called an extractor. They separate a windshield from the body quickly, but
are a very aggressive tool.
Safelite and many windshield shops use a tool that uses wire or string to cut the urethane. Typicall runs against glass, not the body.
Old Feb 22, 2021 | 09:29 PM
4by4ord's Avatar
4by4ord
Mine falls just outside the window..... hehe. Jan 28th build date.
Old Feb 22, 2021 | 09:42 PM
Desert Moto's Avatar
Desert Moto
I just looked at mine, build date 10/20. Now I believe the wind noise I am hearing may be from this problem. Initially I attributed it to the thinner glass or from one of the front doors. Well here we go .......... To the "OP", Thanks for the advanced notice.
Old Feb 22, 2021 | 09:43 PM
OffRoadRN's Avatar
OffRoadRN
This sucks, my truck that I've had for a week was built 1/20. Do I need this to be addressed ASAP? Do I wait to see if I have an issue? What should I do?
