Coolant leak?
Old Feb 22, 2021 | 08:19 AM
zlalonde's Avatar
zlalonde
Coolant leak?
So I have a 2020 6.7 F250 and the was a tiny puddle of coolant under the front passenger side wheel well. It seems to only happen when the truck is plugged in but I have not been able to see where it is coming from. Anyone had any issue with their trucks. I added about 1L of coolant to offset the leak. I would take it to a dealer but am remote and don’t want to make a trip for a minor issue on the truck.
checked the main rad line all lines near the leak and the block heater reservoir and no luck
Old Feb 22, 2021 | 08:58 AM
jimzpsd's Avatar
jimzpsd
No issues to share but based on where your seeing coolant, it might be leaking from the heater assembly itself. Could be loose, it screws into the block.
This video will give you an idea as to its location
Old Feb 22, 2021 | 11:34 AM
zlalonde's Avatar
zlalonde
I checked there and there was no sign of leaks and the leak is coming from the front wheel well and still a mystery might just let it leak and hopefully there is enough evidence to see where it is coming from
Old Feb 22, 2021 | 02:31 PM
senix's Avatar
senix
did you look at the radiator seams?
Also did you pop the hood and look at the T coming off the degas bottle?
Old Feb 22, 2021 | 02:38 PM
zlalonde's Avatar
zlalonde
Yes I checked those and even removed the air intake to get a better look
Old Feb 22, 2021 | 02:47 PM
ford390gashog's Avatar
ford390gashog
My 20 weeps from the heater core connection, I have not brought it in yet for repair.
Old Feb 22, 2021 | 04:31 PM
jimzpsd's Avatar
jimzpsd
Rent a tool to pressurize your cooling system, .............should find it right away
Old Feb 22, 2021 | 06:17 PM
zlalonde's Avatar
zlalonde
Yea that’s the next step in the issue
Kdawg89
Dec 19, 2021 09:01 AM
Richwon4
Oct 13, 2019 11:05 AM
p.ward7885
1978 - 1996 Big Bronco
Jul 28, 2013 07:44 PM
brej
Mar 22, 2005 07:45 PM
jce
Jun 16, 2000 05:16 AM
