Coolant Leak
Old Oct 9, 2019 | 07:55 PM
Richwon4's Avatar
Richwon4
Coolant Leak
Hey guys I am losing coolant out of my passenger side rear wheel well area. It's up high on one of the "conduits". What do I need to do or what it going to cost me?
Old Oct 10, 2019 | 12:42 AM
SmackDaddy's Avatar
SmackDaddy
6.0 I assume?
Old Oct 10, 2019 | 05:34 AM
Richwon4's Avatar
Richwon4
V10
No, should have stated.
V10
Old Oct 10, 2019 | 05:54 AM
seville009's Avatar
seville009
Most likely is the line going to the rear heater vents. If they are original, they are probably rotting out and need to be replaced. Otherwise, maybe just the fittings need to be tightened
Old Oct 10, 2019 | 07:25 AM
Richwon4's Avatar
Richwon4
Tuff Spot
Wow, that is going to be hard to reach.
Old Oct 10, 2019 | 09:46 AM
Lance Helmert's Avatar
Lance Helmert
Probably the heater core for the rear heat leaking. $30-45 on Rock Auto for after market. $94 for a Motorcraft. Check the hose connections first, maybe you'll be lucky and just need to tighten a clamp.
Old Oct 10, 2019 | 04:31 PM
SmackDaddy's Avatar
SmackDaddy
V10
I forgot, heater core is in the same place on all engine offerings. Move some parts, drain coolant from radiator drain, cut both hoses with razor knife as close to the back of the fittings as possible, remove quick connects from heater core nipples, put stainless worm clamps on hoses, slide over heater core nipples, tighten clamps, refill coolant.
Old Oct 13, 2019 | 11:05 AM
rock2610d's Avatar
rock2610d
1st isolate leak location.
If leak is from the ac drain tube under passenger side you have a leaking heater core.
DO NOT EVER USE ANY FORM OF STOP LEAK.
BlueBeauty
Oct 2, 2023 03:22 PM
Fordmamma75
6.7L Power Stroke Diesel
Mar 7, 2018 09:20 AM
jereli
Jan 14, 2014 11:11 PM
cscott952
Oct 27, 2011 11:41 AM
brej
Mar 22, 2005 07:45 PM
