Help!
Old Feb 21, 2021 | 04:36 PM
DavidT89's Avatar
DavidT89
Help!
My mom lost they key for 1969 f250 and I have to change the door locks, ignition and switch. The red wire slipped out of the housing and I don’t know where it goes. The truck fires but dies after I let the key off of start.
Old Feb 21, 2021 | 04:53 PM
1browski's Avatar
1browski
I cant find a red wire on the ignition switch on a couple different schematics.
https://fordification.com/tech/wirin...9charging2.jpg
Old Feb 22, 2021 | 07:55 PM
Lrrr-RulerOfOmicronP's Avatar
Also, I think 68/69 original ignition switch would short out and catch on fire.
It is talked about some by numbers dummy in this thread:
https://www.ford-trucks.com/forums/1...ch-wiring.html
Old Feb 23, 2021 | 06:03 PM
351Cleveland C4's Avatar
351Cleveland C4
Any GOOD locksmith can fit a new key to the existing locks in a matter of minutes....
Old Feb 24, 2021 | 08:45 PM
GLR's Avatar
GLR
There is a key code on one of the lock cylinders. A Ford dealer should be able to cut a key from that. If they still have the machine
Old Feb 24, 2021 | 09:59 PM
RichS2659's Avatar
RichS2659
A Ford key trick: have the ignition key cut on one side of the key blank, and the door key cut on the other side of the blank. Then have the ignition side marked on the new key. This way you only have to carry one key.
Old Feb 25, 2021 | 05:51 AM
GLR's Avatar
GLR
Some of/many of the Ford blanks are different for the doors and the ignition switch.
I found that the ignition keys and the door keys were the same for my 89 wagon and my 86 F250. Thought that was kind of odd.
Oldanvilyoungsmith
Sep 27, 2016 10:30 AM
GoodandPLENTY
Electrical Systems/Wiring
May 28, 2016 05:59 PM
Millermadness11
Sep 2, 2015 12:07 PM
Flathead Meltdown
Jun 13, 2010 02:48 PM
jeremybillie
1983 - 2012 Ranger & B-Series
Jan 1, 2004 02:12 PM
