1980 Bronco VIN
Could someone lend a hand on figuring out the VIN from this door tag. It's an '80 bronco my youngest and I have found down on it's luck. I've seen a few "don't bother with an '80 bronco" threads but we are committed and the price is right. What I see as the VIN is 14 characters. I think it's supposed to be 17, was 11 at some point back in time.
Thanks for any help.
It's a 1980 Bronco, it came with the 351W and it was built in Michigan... Now the H2 axle means 3.50 gear with limited slip
Bullnose VIN Decoder - Gary's Garagemahal (the Bullnose bible)
So I read the VIN as MPVU15GLGG5738. Am I reading that correctly?
The VIN search services on line say I have an incomplete number.
Thanks again.
I read that tag as your VIN being "U15GLGG5738"
This site seemed to work with my VIN and seemed to work with yours also.
http://www.vinwiz.com/
I'd think you just need to find a VIN search utility that accepts older VINs for searching ownership etc. You may need to check with your local title agency or law enforcement and have them look it up.
