Sponsored by: Real Truck
Hole in door
Old Feb 21, 2021 | 11:04 AM
farmerfromkansas's Avatar
farmerfromkansas
Hole in door
Yesterday was attempting to fix a rattle in my drivers door. Took off the door panel, and started trying to shake things to see where the rattle is. Got to the rear window track, where it is bolted to the door at the rear lower, found a piece of metal had broken out around the washer, so there is a hole the size of the washer broken out. Also cracked further out. The metal is too thin for me to weld, Put a bigger washer over the hole for the short run, any ideas on how to repair this? This is a F-450 '05 model, 191000 miles, and hardly any rust. The door seems in excellent condition other than this hole.
Old Feb 21, 2021 | 11:45 AM
WWR's Avatar
WWR
Well other than the obvious of use/find a different welding process, make a sheetmetal plate you can rivet in
Old Feb 22, 2021 | 07:33 PM
farmerfromkansas
Alternative welding process gave me an idea. Cut a piece of 1/8" thick steel, 2 1/4 x 2 1/4, ground it a bit to fit the recess around hole, cleaned up both the door and the patch, cut the slot for the window track adjustment, then put JB weld on the piece of steel, and bolted the track back with the bolt through the patch. After it dries, should be a permanent patch. No more rattle.
Old Feb 23, 2021 | 10:11 AM
Fefanatic's Avatar
Fefanatic
There's always a fix somehow. All you have to do is have a imagination. Great idea for your fix.
akuhr93'f150
16
Jul 23, 2015 03:22 PM
rbaruffi
Oct 3, 2011 10:39 AM
Pickupmanx2
Sep 11, 2008 05:27 PM
rclark1
Jan 9, 2007 10:30 AM
davvalh
Oct 21, 2002 08:16 PM
