Gauge hookup
Old Feb 21, 2021 | 08:31 AM
Anatta's Avatar
Anatta
Gauge hookup
Which wire goes to which terminal on the back of the gauges? Or does it not matter?
On the back of my custom cab with sweep speedo gauge cluster, the temp and fuel gauges have two posts, but neither have any factory markings. It appears a PO wrote with sharpie a “+” and “I” next to each post on each gauge, but that is confusing to me because I would assume that “I” means ignition and that “+” means 12v (same thing in my mind), so then which would be the hot and which would be the sending unit? I’ve seen gauges in the past with a post labeled “S” for sending unit, so something tells me that it does matter and that you can’t just hook them up to either terminal.
I have the factory wiring diagrams, but that doesn’t really help because all of the original wiring is gone, so the color of factory wires means nothing at this point.
im using an EZ wiring 12 kit, if that makes a difference
So my question is, looking at the back of the gauge cluster, which post gets power, and which post goes to the sender?
Old Feb 21, 2021 | 09:27 AM
Sortofa65's Avatar
Sortofa65
I have this picture I don't know why but it appears to be the passenger side. Hope it helps
Old Feb 21, 2021 | 09:53 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Looks like probably + (positive) and - (negative) signs not an I
Old Feb 21, 2021 | 10:10 AM
Anatta's Avatar
Anatta
Doh! Okay well if that’s the case, then the assumption would be that looking at the panel from the rear, the left hand terminal on both the temp and fuel gauge connects to the sending unit, and the right hand gets power?
if this assumption is wrong, what’s the worse that will happen if I hook the gauges up backwards?
and also just to confirm, I’m pulling gauge power off the side of the voltage regulator that doesn’t say IGN, right?
Old Feb 21, 2021 | 10:35 AM
hiball3985's Avatar
hiball3985
Your positive wires have to come from the CVR not a 12V source.
Old Feb 21, 2021 | 11:42 AM
Becky_is_a_66's Avatar
Becky_is_a_66
Here is a 66 custom cab instrument cluster I have out
Old Feb 21, 2021 | 02:55 PM
Sortofa65's Avatar
Sortofa65
Based on Becky is a 66's picture and comparing it to mine I would have to say it must not matter which terminal the wires go on as they are opposite. I can only say mine worked before I took it out.
Old Feb 21, 2021 | 03:08 PM
Anatta's Avatar
Anatta
Thanks guys! Can anyone confirm that it does not matter which post is connected to the sending unit and which post connects to gauge power? I just want to be sure, I don’t want to burn out my gauges! Thanks!
Old Feb 22, 2021 | 12:53 PM
Anatta's Avatar
Anatta
So does it matter which terminal you connect the sender wire or the power wire to the back of the temp and fuel gauges on a custom cab?
There’s no harm if the wires are reversed?
Old Feb 22, 2021 | 06:38 PM
Sortofa65's Avatar
Sortofa65
I looked on Fordification's site at wiring diagrams. Their diagrams start at 1967, however the diagram does show where which wire goes on the gauge. I'd imagine the diagram for your year would also show this.
Old Feb 23, 2021 | 05:01 AM
Crop Duster's Avatar
Crop Duster
I did not read every word in this thread but all the gauges get power from the IVR to the low side of the gauge. IE. "empty", "cold", "0 psi", the other side goes to the senders. The gauges are just measuring current flow to ground.
Old Feb 23, 2021 | 09:19 AM
Anatta's Avatar
Anatta
So just to confirm, when looking at the back of the gauge cluster, the post on the right hand side of the fuel and temp gauges goes to IVR power, and the left hand side goes to the sending unit?
Old Feb 23, 2021 | 10:59 AM
mulegal's Avatar
mulegal
I just went back and looked through all my notes and schematics from my dash rewire....nothing definitive except....BK/GRN from IVCR is the reduced power source to the gauges. Since you have no wire colors to go by, I would attach IVCR feed to where PO had marked + on the backs....I don't think it will damage the gauges with the wires reversed. I seem to remember my fuel gauge bottoming out backwards while I was hooking mine up...reversed the wires and needle moved in the correct direction.
Good luck and keep us posted.
1980 Ford F-250
30
Oct 8, 2024 04:49 PM
Grandpa's66
Jun 15, 2020 04:56 PM
Fords & Whalers
Aug 20, 2016 12:18 PM
Goatjacket
Aug 12, 2012 07:24 PM
tabascom16
Mar 10, 2008 05:54 PM
