1978 - 1996 Big Bronco
4x4
Old Oct 26, 2003 | 09:04 PM
FBB93's Avatar
FBB93
4x4
I bought a 93 xlt about a month ago. It didn't come with the owners manual. I don't know how to turn on or use the 4 wheel drive. I've looked on the internet but haven't been able to find the manual online. If someone could tell where to find a manual online or just how to use the 4x4, it would be a big help. Thanks.
Old Oct 26, 2003 | 10:12 PM
joebronco94's Avatar
joebronco94
To put in 4x4 depends on system that you have. Push button 4hi just push it. 4low put trans. in netral then 4hi,4low. Stick shift put trans. in netral then shift to what setting you want
Old Oct 27, 2003 | 07:03 AM
FBB93's Avatar
FBB93
Its an automatic with the buttons in the dash. They say '4x4' and 'low range'. Thanks for the help.
Old Oct 27, 2003 | 08:11 AM
bronco351's Avatar
bronco351
Well, to use 4X4 just push the button. To use Low Range, put the transmission in neutral the push the Low Range button.
To get out of 4X4 and back into two-wheel drive, just push the button again, and back the truck up 20 feet to fully unlock the hubs.
To get out of Low Range and back into 4X4 or 2WD, put the tranny in Neutral and push the Low-Range button again.
Hope this helps
Old Oct 27, 2003 | 03:52 PM
FBB93's Avatar
FBB93
Do I leave the transmission in neutral when I push the Low Range button, or do I have to shift it?
Old Oct 27, 2003 | 03:56 PM
Kemicalburns's Avatar
Kemicalburns
leave tranny in neutral anytime you push the 4low button . once button lights up or goes out which ever your doing then you can shift out of neutral.
late
Old Oct 27, 2003 | 04:05 PM
FBB93's Avatar
FBB93
ok, thanks
Old Oct 27, 2003 | 04:48 PM
jdgreen's Avatar
jdgreen
I got the owners manual for my Mustang this way. It doesn't have one for my '88 Bronco but yours is newer so it might work.
Go to www.ford.com
Click on owners
Click on my vehicles
Click on My Ford
Go through the sign up procedure
Once you're signed up and at your vehicle's home page click on resources and references.
Then select Owner's Guide.
Old Oct 27, 2003 | 09:11 PM
FBB93's Avatar
FBB93
I tried what you said, i put it in nuetral and pushed the 'low range' button, and nothing happened. The light didn't come on and when i let off the gas, it rolled backwards. Does anyone have an idea what the problem is?
Old Oct 27, 2003 | 09:47 PM
the real Broncoholic's Avatar
did you have it in 4hi first?
Old Oct 27, 2003 | 09:54 PM
FBB93's Avatar
FBB93
I cant get that light to come on either, I dont know if its on or off.
Old Oct 27, 2003 | 09:59 PM
try this
do you have mannuel locking hubs or automatic?
push the 4hi button and see if when you put it in gear it seems slow then its in 4hi if not try again and if it still is not workin you might wanna check your hubs
Old Oct 27, 2003 | 10:41 PM
johnb268's Avatar
johnb268
the transfer case shift motor could be gone. unless you didn't have it in 4x4 before going in to 4low
Old Oct 28, 2003 | 12:33 AM
93xltgt's Avatar
93xltgt
Check out the electric motor on the transfer case. It looks like a window motor. When the Broncos arent used in 4wheel drive often enough the motor wont engage. Locate the motor and you will see several screws on it. Loosen the screws and rotate the motor back and forth. This will make the contacts seat in a differant position with less corrosion. This might help if the motor isnt completly gone. A good mechanic did this for me and said after ' You 4 wheel wanna be guys are all the same, you never use 4 wheel drive and then expect it to work when you never use it. Funny thing is I have to do it to mine right now and quess what I almost never use it. lol. Hopefully this forum will get me in the real 4x4 mode. good luck.
Mike
gtj
Nov 14, 2008 04:26 PM
SpykDaddie
2004 - 2008 F150
Feb 6, 2006 11:29 PM
southpaw
Mar 28, 2005 01:43 PM
checkyoursix
May 12, 2004 01:49 PM
macman85602
Apr 16, 2004 07:30 PM
