2hr No Start
Old Feb 20, 2021 | 10:12 AM
BatiBato's Avatar
BatiBato
2hr No Start
Hello All,
i bought an 7.3 excursion with pats issues. Got a second key and got it reprogrammed using forscan. The theft light went away BUT issue still persist.
Example: I can turn it, no problem, drive it and go to a to b. When I turn it off, it won't turn on unless it passes 2 hrs. I get no crank, no start, no theft light nothing.
I checked all the fuses, changed the bushings on the steering column (was bad), changed the glow plug relay (wasnt getting 12v), starter relay is good, new batteries, need new cable batteries (not sure if that can cause the issue), new starter.
Any ideas??
Thanks
Old Feb 20, 2021 | 10:32 AM
2002Ex's Avatar
2002Ex
Use your ForScan to check for codes. There has to be some with this kind of issue.
Old Feb 20, 2021 | 01:13 PM
projectSHO89's Avatar
projectSHO89
You need to better describe as many observations and symptoms as you can for when it fails. As is, a crystal ball would be needed.
Old Feb 20, 2021 | 06:46 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
we discovered a third party alarm system with a disabler in one of my other vehicles, was causing all sorts of problems, got a shop to remove the third party crap and all the problems went away.
gurinder_s_gill
18
Dec 14, 2015 01:43 PM
handyandy123
Oct 27, 2014 10:14 AM
handyandy123
Oct 25, 2014 06:15 AM
tex welder
20
Mar 28, 2010 09:50 PM
Quick444
Dec 20, 2009 11:42 AM
