Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Rear end ID
Old Feb 19, 2021 | 08:44 PM
a65l's Avatar
a65l
Rear end ID
1985 F800, 429, Spicer CM-40 transmission. Dayton wheels.
Door tag no help:
So I took some pictures. Any ideas?
Yeah yeah, needs some attention from the Pressure washer. AT least it's not gonna rust...
I don't know if this one helps at all, but I took it so...
Old Feb 20, 2021 | 08:27 PM
Tenwheeler's Avatar
Tenwheeler
There is often a metal tag on the center section and or the axle housing. Clean it up and see what you can find.
Old Feb 20, 2021 | 11:49 PM
85e150's Avatar
85e150
If you search "Eaton axle identification", Eaton shows where the numbers are, including ratio in some cases, and lists the numbers as well.
Since you are going to be running this, try one of these:
https://www.hipoparts.com/1980-89-fo...ts-catalog-cd/
It will have axle codes and everything else you might need.
Old Feb 28, 2021 | 09:20 PM
a65l's Avatar
a65l
Thanks for that.. a parts catalog would be very helpfull....
ooraider
Jan 2, 2021 09:43 AM
BlueWhiteFord
Apr 28, 2020 09:01 AM
1990FRANKENTRUCK
13
Oct 26, 2016 06:53 PM
dtgl90vt
Aug 14, 2013 04:03 AM
72F2504BY
32
Jan 26, 2013 09:08 PM
