engine identification issues
Old Oct 26, 2003 | 08:48 PM
diesel1_99's Avatar
diesel1_99
I got time to start on my grandfather's '55 F100. I started by trying to get the info off of the body plate. However, I cannot find the body plate on this truck. It is supposed to be on the driver's door correct? Is there any place else this plate could be located? The door has not been replaced.
Second question-Since I couldn't find the body info I tried to use a couple of parts catalogs to match carb, fuel pump, or anything else i could find to any V-8. Nothing matched. I later found out that the original engine died and was replaced in '75. My grandfather and his brother did the rebuild on what they were told was a V-8 out of a '56 F100, but I still can't match any parts. I thought the engine had a 1 bbl. carb, but this can't be right can it? Did Ford ever make a V-8 with a 1bbl.? And, if not, are there any numbers on the enigne that will tell me what size it is and what year it is?
Thanks in advance for any and all help.
Old Oct 26, 2003 | 09:58 PM
46stude's Avatar
46stude
'55 & '56 should have had a Y block. But all the ones I have seen were 2V or 4V carbs.
Old Oct 27, 2003 | 06:48 AM
55Bubba's Avatar
55Bubba
You should find a data plate on the inside of the glove box door.
As for the engine, looking from the front , does it appear to have a pronounced Y shape? If so , you will find a number for the block on the drivers side, just above the oil filter toward the firewall side of the engine. Then go to the Y-block page and reference the block. If it came out of a 56 it could be a 239 or a 292.
Good luck. Others far more learned than I may be able to offer other information on how to ID your engine
From the outhouse
Bubba
Old Oct 27, 2003 | 09:55 AM
barry's Avatar
barry
The easiest way to I'D' a "Y" block is the valve covers. Does it have 2 studs in the center of the valve cover? If so, it's a Y block. 56 's had the 272 as stock. But it could be a 239, 272, 292 or a 312. Who know if it was original in the 56? Look for casting numbers on the block and heads.
Barry
