2018 6.7L Backfire?
Old Feb 19, 2021 | 07:12 AM
Ratherbe's Avatar
Ratherbe
2018 6.7L Backfire?
Is this a back fire and should I be worried? No response on my thump thread so maybe if I ask it this way. Cruising 60mph - 80mph my 2018 (115,000 mi.) truck is making an occasional thump or dull muffled pop. Sounds like a backfire coming from the engine and usually on the right side. No change in performance or boost. It happens mainly when I use cruise control on level road at 60+mph but not always. At first I thought it was the 1" thick rubber bed rug being picked up on the corner and then falling back down so I removed the rug; Still get the thump. There's nothing obviously loose in the front like a flopping panel or anything. I don't know whether to be alarmed or not. Anyone had this before?
Old Feb 19, 2021 | 07:29 AM
Ding126's Avatar
Ding126
It could be when the truck is in regen ?
Old Feb 19, 2021 | 08:32 AM
Pugga's Avatar
Pugga
Check the front wheel well liner to make sure that's not loose and flapping around. Seems like if it was a misfire at highway speed, I'd hope you'd end up with some sort of code (could be wrong though).
Old Feb 19, 2021 | 09:38 AM
Go Seahawks!'s Avatar
Go Seahawks!
Maybe the torque converter or something in the tranny? I had a 2012 F150 that had a tranny problem that felt like a misfire. Never figured it out after several trips to the dealer. It started at around 15,000 miles and was much worse when I traded it at 60,000 or so.
Old Feb 19, 2021 | 04:54 PM
klbrown's Avatar
klbrown
Do you have OEM front mud flaps? Mine would flex and make a thumping sound.. They also had about a 4" - 5" tear that let them flex more at speed.
Don't have them or the thumping anymore.
Old Feb 22, 2021 | 08:59 AM
Ratherbe's Avatar
Ratherbe
No CEL but I haven't actually pulled the codes. On my short list of to do's but like I said no performance issues yet, just an annoyance I can't figure out.
Old Feb 22, 2021 | 09:00 AM
George C's Avatar
George C
Diesels do not backfire.
Probably a simple turbo huff of spinning ultra fast under hard throttle and then a cut off of exhaust mass from lifting.
They all do it.
Old Feb 22, 2021 | 12:02 PM
Ratherbe's Avatar
Ratherbe
Tried that based on the other threads here. It only pops at low load like cruise control on level terrain with minimum boost.
Old Feb 25, 2021 | 10:41 AM
Ratherbe's Avatar
Ratherbe
Update: since the weather has improved 45 degrees and above I haven't noticed the popping.
Old Mar 30, 2021 | 08:39 AM
Ratherbe's Avatar
Ratherbe
Turns out the dealership replaced #1 glow plug before I bought the truck and did a very poor job of reinstalling the liner. Replaced and tightened the fasteners and the thump went away.
jrez
Jun 29, 2024 09:31 PM
Ratherbe
Feb 16, 2021 11:38 AM
Swantastik
Escape & Escape Hybrid
13
Nov 24, 2014 12:10 PM
okiebandit1
6.7L Power Stroke Diesel
30
May 26, 2013 10:31 PM
Thirsty
1997 - 2003 F150
Dec 2, 2009 04:44 AM
