Sponsored by: Auxito
1997 f-150
Old Oct 26, 2003 | 08:11 PM
randys79crewcab's Avatar
randys79crewcab
1997 f-150
hey gang, what problems would arise if i purchased a 97 extended cab 4x4 a/t with 110,000 miles?
Old Oct 26, 2003 | 10:01 PM
LxMan1's Avatar
LxMan1
You wallet would be much thinner. Hee Hee
If it was well taken care of, probably nothing.
What engine does it have?
Jimmy
Old Oct 26, 2003 | 10:12 PM
bulldogsf150's Avatar
bulldogsf150
i have a 98 with 110,000 on it only problems so far was a bad plug wire.i have only had it about two months
Old Oct 28, 2003 | 01:08 PM
wineman691's Avatar
wineman691
My 97 f150 4x4 is now at about 143k. I have put well over 200k on every ford I have owned. To date only had to deal with minor tune up stuff. I really think your situation will be directed by how the other owner(s) have taken care of the truck. Mine was a fleet truck- Almost all of the miles were highway. Doens't take away from anything but I would rather buy one with a lot of HWY miles than someones tired old work truck.
Make sure you have a qualified tech take a quick look. Heck for about $100 there are certified pepole who will come to you to do this, you don't even have to move the truck from where it is.
Good luck
Old Oct 28, 2003 | 10:37 PM
03f150man's Avatar
03f150man
156,000 on my 97F150 4.6 auto. absolutely zero problems. just maintenance. the posts below are correct, maintenance is the key.
Old Oct 31, 2003 | 09:21 PM
geoaigel's Avatar
geoaigel
A well maintained 4.6 with 100k is barely broken in.
George (168k)
Old Nov 2, 2003 | 08:57 AM
tm3912's Avatar
tm3912
I bought a '97 , 4.6, 100,000 mile a year ago. No problems that routine maintenance haven't taken care of . If the price is right go for it.
Old Nov 2, 2003 | 04:22 PM
Fordtrucktexan's Avatar
Fordtrucktexan
I bought my 97' in July '02 with 111k on it, 1997 F-150 ext. cab Lariat with the 4.6 auto and 3.55 rearend. I've absolutely loved it but the previous owner did very little in maintenance so the past year I've sank quite a few fistfulls of cash into catching up.
With a tuneup, and pretty much a whole new front suspension and steering system, it runs and drives like a champ. I can go into detail if you need to know what all I've replaced. This morning she proudly rolled over to 149k miles.
Old Nov 13, 2003 | 12:26 AM
arj3's Avatar
arj3
I bought my '97 SC,LB 4x4 in May. had 101K on it. Did a tune up for about $150 - hoses, belt, plugs, wires (4.6), oil, filter, K&N clean kit. The only other things were a set of brakes, a starter (never 4-wheel in water and mud past your floor boards!), a heater core (the reason I got the truck dirt cheap). Soon it needs a new set of 315/75R16's, but that's to be expect and I am going to change the diff oils because the rear has a leak and I have been in some major mud and water. Oh! last sue . The previous owner had a new tranny put in it. The papers from the dealer say the overdrive band was cooked, my guess is towing with O/D on.
Moral to the story- most everything done to it was self-inflicted. I bought the truck after working at a Ford dealer. The trucks that need work had over 300K miles or were beaten or not maintained.
Old Nov 13, 2003 | 03:02 PM
Diamond-X's Avatar
Diamond-X
I just traded in my 1997 F-150 XLT 4.6L, it hadd 110,000 miles and no problems. I had been towing with it so there was a little shift hesitation but I purchased a Chip mod which resolved that.
Old Nov 13, 2003 | 10:03 PM
yukonhighboy's Avatar
yukonhighboy
Howdy,
I purchased our f150 with 60k on it and have put another 40k on with no trouble other than some electrical gremlins like wipers that have a mind of their own and intermitant interior / door ajar lights. other than that all i've done is routine maintenance.
great truck altogether
see ya
Bob
Old Nov 28, 2003 | 10:47 AM
Renegadesrun's Avatar
Renegadesrun
Ive had my 97 4x4 SB for a couple months. Has 123K and only minor issues.
Rear brakes replaced already.
Needs springs...sits low left
needs shocks.....they are original
front tires....already bought 2 nice toyos for the rear
Other than a cluck on take off if i goose it, and some lifter rattle it runs and performs perfect.
It looks as if it reasonably maintained.
Old Feb 25, 2004 | 02:24 PM
Bigrig1904's Avatar
Bigrig1904
My 1997 f150 4x4 ext cab.. 96650 miles just had the head gasket done on the pass side. Had antifreeze in the #4 cyl. but all in all I like my Ford and $1800 poorer.
Old Feb 27, 2004 | 10:42 AM
DaMan28n88's Avatar
DaMan28n88
Hopefully the truck you are buying is the v8 because the 4.2 l has the faulty gaskets and cost me $1200.
Old Feb 27, 2004 | 01:02 PM
toxophilite's Avatar
toxophilite
I like this post...I bought a 97 F150 4.6 auto 4X4 Longbed in August with 42,000 miles on it...other than oil changes I've put a K&N intake on it, serviced the tranny and replaced the filter, and drained and filled the transfer case. The vehicle now has 49k on it and I'm planning on flushing the radiator before summer comes. Is there any other maintenance you guys can recommend right now? I was planning on doing the plugs and wires at 60k.
