Headlight conversion problems
Old Feb 17, 2021 | 08:51 PM
Matt5330's Avatar
Matt5330
I have a 1987 F250 6.9 diesel that I put a 95 front clip on. I had to use the 95 bulb holders to go into the 95 headlight bezels and plugged them into the 87 wiring harness and now the lights are really dim. Do I need to switch some wires around to make the older harness work?
Old Feb 18, 2021 | 06:44 AM
Franklin2's Avatar
Franklin2
In 1995, lightgreen/black is the high beam to the socket, red/black is the lowbeam wire. Black is ground. Take a short piece of wire and connect it to the black wire, and then touch it to the negative of the battery. Do they get brighter? If they do, you have a grounding problem with the front sheetmetal. If you painted everything up really nice when you did this conversion, that can be a problem with grounds.
Old Feb 18, 2021 | 04:44 PM
Matt5330's Avatar
Matt5330
Thank you, I'll try that this weekend.
BAD RONALD
Aerostar
16
Feb 12, 2012 08:38 AM
VanDiesel
Nov 9, 2010 05:25 AM
davzog
Oct 16, 2010 09:10 PM
jwtimme
Oct 5, 2007 03:25 PM
FAB150
Nov 5, 2004 07:51 PM
