What size wheels should I get, I like a wider look. Also what size tire can I throw on with a level.
Edit: 2010 F-150 XLT 2inch level. Stock 18inch rims not sure on tire size.
It would really help to know what vehicle and pertinent equipment you have. You know, things like current tire size & rim size, any lowering or leveling you've done, etc.
Reminds me of an old parts counter joke:
Kid: I need some spark plugs and an air filter for my bike.
Parts Guy: Sure, no problem. What bike ya got?
Kid: It's blue.
Kid: It's blue.
Thought I had that in there, thanks. Lol! Did sound very similar to that situation.
Miles Edwards - What size wheels should I get, I like a wider look. Also what size tire can I throw on with a level.
Stock sizes ... (should be able to go +2" diameter and +1" wider without changing offset - best bet would be to measure)
. HINT/TIP: Put your vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature -OR- provide it in your posting(s).
Ok, gotcha. Honestly I can't help much as I typically just go up or down a size or two to get what I want. I've never had a problem doing this without replacing rims. Going wider shouldn't affect anything but note that my 2013 is particularly sensitive to taller or shorter. I had to use the Forscan software to correct my speedometer- 1 size change in tire size altered my speedo accuracy by 4.5 mph. Drove me nuts!
