So I was playing around with my exhaust finding the best low and midrange tq by playing with a mix of my welded X and h pipes and I like this the best, its 3 inch all the way with a small 1 inch x pipe between both pipes then its a couple straights out to a y pipe a couple feet down and 24 inch long 3 inch glass pack and then 5 inch diameter 1 ft long resonator tip
Can you guess my motor and can you all share your setups here,, if its not rhe right place can i be notified so I can save the contents then have it moved to where it belongs,, thank you and hope yall had a happy presidents day weekend/valentines
I don’t have a sound clip of mine but I put long tube headers on mine which then runs into electric cutouts and then into two original 40 flowmasters then dumps out under the truck near the cab/bed crack.
