RPM's don't work
Old Feb 18, 2021 | 09:05 AM
JustinCollins's Avatar
JustinCollins
RPM's don't work
Hello I have a 1985 F250 with a 7.5L. I have been having a problem with my RPM's not working. I am not sure what could be making this happen I have checked and fixed the circuit board on the back of the instrument panel so I know it is not related to the electrical or the traces on the back of the instrument panel . Does anyone else have any idea what else cold be casing my RPM's not to work? Thank you for any suggestions!
Old Feb 18, 2021 | 11:23 AM
1986F150six's Avatar
1986F150six
With the Duraspark ignition system, there should be connectors on the inner fender on the driver's side. One will have a green colored wire coming from the coil. This provides the electrical signal for the tachometer. Check for looseness or damaged wires.
There is a connector with two black [I think] wires which provide the two necessary grounds for a V8 engine. Six cylinder engines just have one ground for the tachometer.
On the back of the tachometer are 4 terminals: "B" = battery [12 volts]; "C" = coil [green wire from the coil]; "G" = ground [for 6 & 8 cylinders; "8" = 2nd ground for V8 engines only.
With the tachometer removed [for testing], connect jumper wires to the appropriate places and see if the tachometer works.
Be very careful regarding moving engine parts while testing.
Aussie_F_trucker
15
Mar 1, 2016 10:02 AM
Bmer05
2004 - 2008 F150
Dec 17, 2012 07:20 PM
austinramsay
Sep 23, 2011 08:07 AM
howlingwolf
Oct 14, 2007 09:51 PM
catbird7
May 1, 2002 12:51 PM
