Do I need a new PCM?
Old Feb 15, 2021 | 09:59 PM
GoldCo's Avatar
GoldCo
Question Do I need a new PCM?
I've got a 5.8 with factory PCM and harness in my '52 which has been running fine for over a year… lately, however, I'm having some issues (inconsistent):
1) driving down the road under normal acceleration, will lift off throttle pedal in advance of an intersection and the engine speed will pulsate a few times (rev up, down, rev up, down, rev up, down) before settling at normal idle speed as I come to a stop.
2) more problematic -- a few times now when I lift off throttle, the RPMs will not drop down to idle at all, so if I don't shift (E4OD) into neutral as I approach intersection, the engine will stall when I come to stop. Sometimes I can blip the throttle to make it correct itself.
Thoughts? Insight? No code being thrown to CEL. Truck runs fine otherwise, so wondering if this PCM is going bad??
Old Feb 15, 2021 | 11:49 PM
Conanski's Avatar
Conanski
Don't guess hook up a code reader and have a look, not all codes set the CE light.
Old Feb 16, 2021 | 05:40 PM
wwhite's Avatar
wwhite
You say "the RPMs will not drop down to idle at all," and "the engine will stall when I come to stop"
I don't understand, the RPMs are high, and the engine will stall when you come to a stop?
Sounds like the torque converter is locked when it should be unlocked.
Old Feb 16, 2021 | 06:19 PM
Scndsin's Avatar
Scndsin
You did keep the diagnostic connector when the harness came over?
Old Feb 16, 2021 | 10:59 PM
GoldCo's Avatar
GoldCo
Yes.
Also have a ODB1 reader, so guess I'll give that a shot…
Old Feb 16, 2021 | 11:00 PM
GoldCo's Avatar
GoldCo
Agreed. So PCM controls TC, no?
Old Feb 16, 2021 | 11:02 PM
GoldCo's Avatar
GoldCo
Will do. Good to know…
Old Feb 17, 2021 | 01:44 AM
wwhite's Avatar
wwhite
Yes, the Torque Converter lockup is controlled by the computer via a solenoid.
Have you checked the electrical connections on the trans, make sure they are clean and no corrosion.
Do you have a transmission cooler or a transmission temperature gauge?
Being in a '52, I'm sure its used to burn some rubber. Do you do burn outs in drive?
Did you rebuild the transmission, or install the pressure regulator assembly and the TCC function that is in the pump, as recommended a few years ago?
Old Feb 18, 2021 | 10:57 PM
GoldCo's Avatar
GoldCo
Cool other ideas?
Only codes were the expected ones for this install… 311 & 327 since I've got EGR disabled for this build.
Old Feb 18, 2021 | 11:03 PM
GoldCo's Avatar
GoldCo
This was a clean, frame-off install … E4OD out of a '95 Lightning truck with only 30K miles, tranny gone through by the shop I purchased it from. No problems until recently.
Yes, running tranny cooler.
Not so much a burnout truck pushing the dually rear-end. Healthy motor though with great exhaust tone (headers and Raptor mufflers).
Don't know anything about the regulator or TCC you refer to??
Old Feb 19, 2021 | 10:49 AM
wwhite's Avatar
wwhite
There was mention to upgrade/install in one of your previous posts, I think it was in the post talking about installing a shift kit.
I believe the stock plastic one can overheat/melt, specially if trans is used hard, and doing burn outs in D not 1.
This might be for overdrive, not torque converter lockup.
From what I recall, if/when this part fails, it will stop fluid from the TC lockup releasing. It's a small part, that could be the cause of your issues. Its located in the front pump assembly.
But, Before diving into trans, I'd focus more on the electrical. Inspect the inside of the EEC for bad capacitors.
DO NOT use an older EEC. Your 1995 EEC has diodes that were not in 1994 and older EECs. The solenoid pack on 1995 E4OD does not have diodes, and can cook/fry 1994 and older EECs. 1994 and older have diode in trans, not EEC.
Do you have the ATSG E4OD document? It will have specific trouble shooting procedures for solving your issue. I'll find it, and see what it says.
Old Feb 19, 2021 | 11:27 AM
wwhite's Avatar
wwhite
OK, so that was the KOEO Quick self test.
Now, hopefully your truck is still drivable, you can do the following "Drive Cycle Test", and attempt to get a code set.
Old Feb 19, 2021 | 08:30 PM
GoldCo's Avatar
GoldCo
Exclamation thank you!
Interesting… I am (unfortunately) familiar with bad capacitors — this EEC is actually a replacement I picked up not long after putting the truck together, as the original one which came with the motor/harness was acting erratic as I was finishing the build — actually had the weeping capacitor once I tore it open. I'll have to see if I have the invoice from this pull-and-pay replacement, as I don't recall for sure what year it was specifically. FWIW it's been running great for 16 months (no burnouts!).
I do not, thank you.
Old Feb 19, 2021 | 08:34 PM
GoldCo's Avatar
GoldCo
Thumbs up
OK, so that was the KOEO Quick self test. Now, hopefully your truck is still drivable, you can do the following "Drive Cycle Test", and attempt to get a code set.
Wow, thank you very much! Yes, still driving daily. I'll give this a shot this weekend. Yes, those codes were after both the KOEO test and the engine running test. I'll double check tranny fluid and try to look for pinched wires just in case. If I recall, these EECs weren't easy to come by (at least locally).
Much appreciated!
Old Feb 19, 2021 | 08:54 PM
Scndsin's Avatar
Scndsin
You can always pop it open & look for leaky capacitors. What did yo do with the speedo/PSOM/VSS circuitry?
