Transmission Swap!
Old Feb 15, 2021 | 07:19 PM
PieceOfJunk's Avatar
PieceOfJunk
Transmission Swap!
Hey everybody,
I spent all day Installing a floor shifter because my shift collar broke on my 1980 f100 3 on the tree. It was a pain in the butt and it hits my bench seat.
Anyways, I was thinking about returning the floor shifter and just swapping an automatic transmission from the junkyard. I found another 1980 F150 with an AT. My question is what all would need to go into making this change? I know that I would have to put a new steering column on and I would probably just grab the gauge cluster from the same truck.
They are both 2 Wheel drive. What other parts would I need? Is this a pretty easy installation?
Old Feb 16, 2021 | 05:07 AM
Rembrant's Avatar
Rembrant
What engine is in your truck, and what engine is in the one at the junkyard? You need to be very careful swapping flywheels and flexplates on these trucks if you have a 300, 302, 351, etc.
So you'll need the correct flex plate for your engine. 302 and 351 flexplates are interchangeable sometimes, but not always.
You'll need the starter for the automatic trans.
You should also grab the transmission crossmember and driveshaft, cooling lines to rad, etc.
Old Feb 16, 2021 | 08:03 AM
PieceOfJunk
Trans swap
I have 4.9 300 i6. I’m not sure what transmission is in the truck at the junkyard. All I know is that it’s an automatic. I purchased a hurst Indy 3-speed universal shifter and it’s terrible. If I don’t do the auto swap, My only other option is to get a hurst mastershift shifter. Anyone have a good experience with this?
Old Feb 16, 2021 | 10:39 AM
Franklin2's Avatar
Franklin2
Why not look for a old 4 speed and bolt it up? They came with floor shifters factory. It might slip right in place, and there is a chance you might not need driveshaft work. I am thinking you could use your old 3 speed bellhousing with the 4 speed, not positive on that though.
Old Feb 16, 2021 | 04:28 PM
john jamieson's Avatar
john jamieson
I'm surprised no one makes a replacement shift collar, for a 1980
Old Feb 16, 2021 | 05:08 PM
FuzzFace2's Avatar
FuzzFace2
POJ, where in NC are you? Close to Raleigh?
To swap to an auto is a lot of work and not knowing what that JY one is its hard to say if it would be worth the work for a swap or if it is even any good?
See if that JY has any of the later 5sp that would have over drive. As long as the transmission is from a small block it will bolt to your 300 six motor.
Yes a 302 & 351 are small blocks.
You will need the pedal assy. as the newer trans use a master & slave to work the clutch and the clutch pedal & shaft are different than yours.
Get the trans w/shifter, the pan that fits over the transmission hump, master & slave (to match up if you get new), cross member parts and drive shaft and it may be a bolt in other that the drive shaft.
You would not need to swap flywheels and your clutch should work but I would replace it being you are there already.
I think the 5sp would be the best way to go at this time but that's me.
Dave ----
Nobby
Jan 15, 2012 10:02 PM
Timbo1985F150
Feb 15, 2007 11:41 PM
sailorjohn
Bronco II
Dec 31, 2006 06:30 PM
nitrouskid
Jan 4, 2001 07:26 AM
