96 f150 5..0 eddie bower
have a issue with no start .I e changed , pligs,wires, ,injectors,fuel filter ,fuel pump ,mass airflow sensor and still no start . It want to fire but won't stay running ,. Any ideas?
Did it start before you worked on it, or you bought it that way?
Do you hear the fuel pump prime, when you turn key to 'on' position, 2 tanks? check fuel pressure with gauge, check for codes, even if CEL isnt on, could have stored codes
