Right rear locked
Old Feb 14, 2021 | 01:19 PM
joelbarras20's Avatar
joelbarras20
Right rear locked
ok have been searching cant find anything with this exact problem. Right rear tire locked up jack it up it turns freely put the weight of the truck on the tires locks up removed drive shaft and all the brakes does the same thing with the truck jacked up i can engage and disengage the elocker seems to work fine. heres the catch it moves and drives fine in reverse. My 2013 f150 eccoboost 2wd 9.75 rear end 3.31 gears with the elocker. any body else ever have anything like this
Old Feb 14, 2021 | 05:19 PM
rbentnail's Avatar
rbentnail
Checked the emergency (parking) brake?
Old Feb 14, 2021 | 06:20 PM
joelbarras20
took all the brakes completely off the rear of the truck thought that was the problem too but no such luck
Old Feb 14, 2021 | 06:26 PM
ford390gashog's Avatar
ford390gashog
Broken side gear cross pin retainer. Pull the cover and look for ruined spider gears and a Broken pin.
Old Feb 14, 2021 | 06:56 PM
joelbarras20
looked at it all that didnt see any damage have to take another look didnt find any metal in the bottom of the diff
Old Feb 14, 2021 | 11:39 PM
Lime1GT's Avatar
Lime1GT
With the right rear brake drum off is the park brake apply lever seized? Sometimes the park brake shoe lining separates from the shoe and will make it difficult to remove disc drum.
Old Feb 17, 2021 | 11:53 AM
joelbarras20
pulleed the pin which has a little play the spider gears have some slack in them and make a some noise when i move them by hand with the pin in place axle shafts removed when i barely pry out on the spider gears it seems to lock up.
Old Feb 17, 2021 | 02:31 PM
Lime1GT's Avatar
Lime1GT
Sorry for last comment, Missed one of your replies. I did find a video explaining how the e-locker works which I found interesting. Especially about the initial axle slip when engaging. Starts at 4:17.
Redneckmorton
Aug 23, 2017 08:55 PM
77 2wd
Sep 9, 2012 09:23 AM
78RangerSuperCa
Nov 26, 2006 03:31 PM
lsulaw504
Aug 16, 2003 11:13 AM
medicpg
May 17, 2003 05:33 PM
