Steering/body roll problem
Old Oct 26, 2003 | 06:18 PM
ford76special's Avatar
ford76special
Question Steering/body roll problem
Help! I have a 76 F100 camper special that I am restoring and have a problem with control. Steering does not return when coming out of turns/corners and the whole truck seems to sway. I have put all new front end components and even a new steering gear box. It has been aligned. I drives great on the flats but the control around corners and under hard braking is the pits. It has a 390FE but front end weight was reduced because of the aluminum intake system and the removal of the A/C system. Any suggestions?
Old Oct 26, 2003 | 10:30 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check the caster again. These are also trucks, not sportscars. The camper special has a swaybar front and rear if I remember right. Dennis probably has better info on that tho. A vehicle with only a rear swaybar can sometimes behave strangely.
Old Oct 26, 2003 | 10:51 PM
plowpusher's Avatar
plowpusher
is the steering box set to tight there is a jam nut on the steering box to take some play out of the sector if that gethow good are the shockss set to tight it will not come back to center after making a corner. how good are the shocks?
Old Oct 26, 2003 | 10:52 PM
LxMan1's Avatar
LxMan1
Springs worn out? The shocks in good shape?
Jimmy
Oh, and Welcome to FTE
Old Oct 27, 2003 | 12:15 AM
GeneStoner's Avatar
GeneStoner
An F-100 Camper Special???
Old Oct 27, 2003 | 12:38 AM
Torque1st's Avatar
Torque1st
Posting Legend
You saw that too -hehe
Old Oct 27, 2003 | 06:17 AM
grapegravy's Avatar
grapegravy
That's exactly why he's having problems, Gene. Truck doesn't know what's going on
Old Oct 27, 2003 | 09:17 AM
73Custom's Avatar
73Custom
Is there such a truck?
Marty
Old Oct 27, 2003 | 05:59 PM
Torque1st's Avatar
Torque1st
Posting Legend
Methinks somebody has been using superglue at the salvage yard.
Old Oct 27, 2003 | 09:15 PM
ford76special
Thanks!
You guys are good. It was a mistake on the camper special. It should have been Trailer Special. Sorry bout that. Anyway I am the second owner of this truck and just trying to do it right. The front suspension is all new. Shocks, springs center link, tie rods, drag link, pitman arm, king pins, axle pivot bushings, etc.. I do realize that it is not a sports car but I think that this problem can be fixed. As for the sway bars- none were ever on this truck. I have put Hooker comp headers on and the OEM sway bars will not clear them. Could the frame rivots be allowing excessive flex? A friend told me to look into boxing the frame. Thanks for the replys.
Old Oct 27, 2003 | 09:46 PM
Ecuri's Avatar
Ecuri
Where is your camber set? As I guess you know, Eric is pointing you towards the caster for the effect it has on returning to center. I think Ford had some crazy +1 or +2 degrees of camber. Ignore this (IMHO). I think their idea was that when the truck is loaded down the camber would come back towards zero. Swing axles (which is what an I-beam is) love negative camber for better handling. I like about 1/2 to 1 degree max. negative...not so extreme as to upset tire wear dramatically... but enough so when hard in a corner the suspension doesn't want to "jack up". I suspect this is what you are experiencing.... once it starts, it only gets worse.
Look at any old VW... the rear wheels are always splayed out (lots of negative camber).
Old Nov 1, 2003 | 12:30 AM
palmrose2's Avatar
palmrose2
How is camber adjustable on these TIB trucks? I thought toe was about it without different springs or bending beams.
Old Nov 1, 2003 | 12:49 AM
Torque1st's Avatar
Torque1st
Posting Legend
Take the truck to an actual front end alignment shop that works on heavy trucks. They can align the truck properly. The normal alignment shops can only set toe. They are not equipped with the tools and knowledge required to do the job. The HD truck shops can bend the beams properly, they do it on the HD trucks all the time.
Old Nov 1, 2003 | 08:04 AM
ford76special
Thanks Torqu1st- and everyone. I have found a HD truck shop that says they can take a look at it. Any feedback on boxing the frame? What would be the negitive of putting a Mustang2 front end (with larger springs) on my Truck and adding a disk brake package to the rear? I know its not a sports car......
Ford76 special.
Old Nov 3, 2003 | 12:02 AM
palmrose2's Avatar
palmrose2
I would interested in the specs the HD shop sets the front end to if when they are done it drives well.
