clutch safty switch
Old Feb 13, 2021 | 04:08 PM
rip357's Avatar
rip357
clutch safty switch
how do I bypass css on a 1984 ford f-250?
Old Feb 13, 2021 | 04:45 PM
diggerrigger's Avatar
diggerrigger
If you know where the switch is above the pedals, look for a two wire connector at the clutch switch. Should have red/light blue wires. Unplug and jumper. Or fix the common problem as shown HERE.
Old Feb 15, 2021 | 11:49 AM
FrankTheMechanic's Avatar
FrankTheMechanic
Don't "fix" the switch unless you can't remember to take the truck out of gear prior to starting. Jumper the wires and never look back.
Having to push in the clutch while starting is pretty hard on the thrust bearin, as there's not much oil pressure to lubricate it.
Old Feb 15, 2021 | 06:14 PM
FuzzFace2's Avatar
FuzzFace2
When I was leaning to drive I was told ALWAY PUSH THE CLUTCH IN when starting a stick car or truck.
That is almost 50 years now and I still do it to this day.
How long do you think it would take to wear that thrust bearing?
What about sitting at a stop light or sign with the clutch in?
And if that was the case what about every time you go to start the motor and the bearings not having oil to them also?
Push the clutch in before turning the key and don't look back!
Dave ----
Old Feb 15, 2021 | 06:54 PM
Franklin2's Avatar
Franklin2
He's right, an engine that has a clutch behind it will have wear in the thrust bearing and the thrust flange on the crankshaft. No way around it, but you can mitigate things a little bit. Starting it out of gear will help, but anyone with the clutch switch working doesn't have that luxury. But while you are stopped at a light, I always pull the tranny into neutral and let out on the clutch. This lessens the thrust time against the bearing, and it also lessens the time the clutch throwout bearing has a lot of pressure on it.
But even with those measures, you will often find the crankshaft that has been in front of a manual transmission is out of spec when you are checking the crankshaft end play.
Old Feb 16, 2021 | 02:48 PM
FrankTheMechanic
Dave ----
Dave,
You do you.
I always, without fail, put the truck in neutral before I start it. If you don't want to modify your CSS, don't, and we'll get along just fine.
Old Feb 16, 2021 | 03:06 PM
matt167's Avatar
matt167
I used to daily drive a '74 MGB. On those, it's actually in the factory manuals to NOT push the clutch in when starting due to the type of thrust bearing. They got away without a clutch switch until the car/ brand went away in 1981. IIRC they did wire the safety through the brake light switch instead, eventually but my '74 didn't have that.
My spare vehicle, a 1993 Suzuki Jimny that I imported from Japan has no clutch switch from the factory and Toyota trucks up into the 2000's had a bypass switch
Cole Eakle
Jan 16, 2020 12:02 PM
IDIDieselJohn
Nov 26, 2013 05:23 PM
Old Salt
1983 - 2012 Ranger & B-Series
Oct 30, 2003 07:27 PM
raeandjim
Oct 28, 2003 01:19 AM
