I noticed the knock sensor wires were damaged, so I ordered a new knock sensor and intake manifold O rings. Took off the intake, replaced the knock sensor. Cleaned things up while I was there, put it all back together.
And now I'm getting a vibration in the throttle pedal, right around 2000-2500 rpm. What gives? What did I do? What do I need to check?
Seeing as how you've had the intake off, check the throttle cable & its mounting flange, fasteners, etc, to make sure all are aligned, unbent & properly fastened & let us know what you find.
