2015 F150 Brake Recall
From what I've read the recall involves changing the master brake cylinder. So it is possible they did a poor master cylinder bench bleed and brake bleed as well. I'd take it back and see if they'd cover another system bleed. If they changed the brake booster as well it's possible the booster rod needs adjustment if your pedal doesn't feel like it applies in the same spot.
78 crew 4x4 short
03-22-2004 02:50 PM
