fuel tank in highboy
Are you sure on that #? What type of vehicle did the tank come out of originally? A 84-90 little Bronco II by chance?
https://shop.broncograveyard.com/Bro.../products/312/
https://www.ford-trucks.com/forums/1041266-bronco-ii-tank-in-highboy.html
https://www.ford-trucks.com/forums/5...r-highboy.html
https://www.ford-trucks.com/forums/1376107-rear-gas-tank-for-highboy.html
https://www.ford-trucks.com/forums/1...n-highboy.html
https://www.ford-trucks.com/forums/1...r-highboy.html
70's dually would/should NOT have a plastic tank. Unless if was the in front of the rear axle, mounted inside the frame. I know you can get a rectangle shaped plastic tank on a 79 F250 4wd in front of the axle, mounted inside the frame.
So just where did you get that engineer #? d8ta9002eb
And is that tank aft of the rear axle and in between your frame rails?
Rebuilt Fuel Sending Unit Specialist (tristarrradiator.com) I have no experience with them, but might try and give them a call.
Hmm, I can't place where that tank would have been sourced from either. I'd say a chevy dually but those are ford numbers. Here's a picture I have handy of a 1993 cab and chassis gas tank (on the left) and a 1977 camper special tank and shield (on the right). Neither one matches your tank... Maybe its a bronco tank?
410 Highboy
12-23-2013 06:18 PM
