General Automotive Discussion
2002 Exlorer ENGINE SWAP suggestions?
Old Feb 12, 2021 | 11:38 AM
Larry D.'s Avatar
Larry D.
Hi. First Post here. I have a hard time junking this Explorer with a good chassis (Texas weather) And no dents or dings in the body AND GOOD paint. It is more practical for me then a pick up truck of the same vintage. I have had the " death rattle" of the cam chain tensioner come and go. Etc. Short story is I will keep this truck/SUV if I can get a used and decent running engine into the chassis. I wonder if the 4.6L V6 is a good choice and will it bolt up to the automatic transmission the the 4.0 came with? If the overall level of work is near the same then a 302 V8 with a five speed would be my choice JUST because this is my last wrenching project on four wheels and I LOVE standard transmissions! I am old school and have the tools and garage to get this done plus I am retired and have the time. This I a RWD not 4wd. A small block iron OHV Is something I can relate to. SOHC or DOHC, Fuel injection and smog control I no longer need? It is going to be a ranch to market truck with Farm registration. So this is my spare time 'toy'. Just for the record. I have never owned a new car or truck. My only other truck was a 1960 Dodge D100 with a small block chevy and Ford nine inch rear differential. There's also a 1973 Toyota Celica with a BMW 1800 and 4 speed sitting under the hood of it. That was Germany and I doubt it would EVER get shipped stateside. Any suggestions for the engine swap would be appreciated. Thanks. Larry
Old Feb 13, 2021 | 06:00 PM
tjc transport's Avatar
tjc transport
i ain't rite
302 into the exploder is a very popular and doable swap, since they came with that engine from the factory.
a 5 speed would be a little more work, but it sounds like a fun driver.
Old Feb 16, 2021 | 01:01 PM
Johnny Paycheck's Avatar
Johnny Paycheck
You mean 4.6 v8, right? If so, you’ll need the transmission that comes with it as it has a different bellhousing bolt pattern.
Read this fella’s thread:
https://www.explorerforum.com/forums...plorer.377456/
Old Feb 17, 2021 | 12:11 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
You'll never get a 4.6L under the hood as there is not nearly enough clearance on the sides (heater box and brake booster). The 4.6L is HUGE. A turd. But huge!
Old Feb 17, 2021 | 12:20 PM
tjc transport
i ain't rite
that is why i said 302.
Old Feb 18, 2021 | 02:55 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I put a 4.6 in place of a 390 last year. Damn thing almost doesn't fit......not front to back or top to bottom......but side to side. Conversely I put a 7.3 PSD in place of a 4.6 and just had to work on the top to bottom aspect.
Old Feb 18, 2021 | 03:51 PM
tjc transport
i ain't rite
i considered putting a V10 in a 64 falcon....... for about 30 seconds.
it would have looked like an econoline van with the engine half under the dash.
or i would have had to extend the nose around a foot.
Old Feb 22, 2021 | 11:35 AM
Larry D.'s Avatar
Larry D.
GOOD information! Thank you.
The 302 it is. I think fuel pump died. I checked the relays by swapping out other relays of same amperage like blower motor. Its the priginal pump and 187000 so no surprise. Turns over fine and usually fires right up. I already replaced the electrical contacts at the base of the ignition lock. The truck is parked where I can start this project. Time to recover from the worst ice storm I have ever seen but thanks again. It WOULD have to be a full tank. Sorely tempted to put an external fuel pump under there. Anyone done that ? Thanks again. Larry
the
Rob Carpenter
1983 - 2012 Ranger & B-Series
Jul 20, 2020 06:38 PM
640 CI Aluminum FORD
7.3L / 6.8L V8 Gasoline Engines
Apr 14, 2019 09:03 PM
redlines4us
May 8, 2006 05:28 PM
Mudder
Apr 11, 2005 11:16 AM
