Why is it hard starting when cold?
Old Oct 26, 2003 | 04:41 PM
1990Fordf150v8's Avatar
1990Fordf150v8
Unhappy Why is it hard starting when cold?
I have a 1990 F-150 XLT X-cab short bed with a 302EFI automatic 2 wheel drive. Why is my truck hard starting when it's cold? I have new plugs, wires, dis cap, and air filter. Please let me know what you think is going on with my baby. Thanks again everyone
Old Oct 26, 2003 | 05:17 PM
SteveM's Avatar
SteveM
hard to start ?
when i first bought my 94 f-150 with efi, i had to stomp the pedal like a carb and it was tpi sensor. i think my 88 may be same
because it will die, idle at light.
i don't think early versions of efi would show check light untill it gets very bad.
hope this helps.
you can use the search on this form for older threads also.
Old Oct 26, 2003 | 05:23 PM
1990Fordf150v8
ok thanks stevem, How much do TPS cost? Did you mean that not tpi?
Old Oct 26, 2003 | 05:41 PM
Hit Man X's Avatar
Hit Man X
Throttle position sensor maybe I'd say the IAC is going bad. Do you have idle surge also?
I'd say a TPS is about $40 the IAC a bit more. When I repaced my IAC it helps a TON with my cold start idle surge.
Old Oct 26, 2003 | 05:45 PM
SteveM's Avatar
SteveM
hard to start
yes------tps------ long day, sorry.
mine was $30 at auto advance.
hope it helps ,used an allen wrench i think
Old Oct 26, 2003 | 05:50 PM
1990Fordf150v8
Hit man X Yes i do have idle surge also. What is the IAC and where is it and what does it look like?
Old Oct 26, 2003 | 05:51 PM
1990Fordf150v8
Stevem thanks for the price and info
Old Oct 26, 2003 | 07:48 PM
Hit Man X's Avatar
Hit Man X
The IAC bolts to the TB via two small 5-8mm bolts. There is a pair of wires running to it also. It's easier to take the TB off and replace the IAC but isn't necessary to. I tried to clean my old IAC a few times to no avail so I just broke down and scooped up a new one.
To swap the TPS the TB has to come off.
Old Oct 26, 2003 | 10:10 PM
KeelarPluto's Avatar
KeelarPluto
My 90 F150 w/ 302 does the same damned thing! Now what do all those abreviations mean? TB, TBS, etc etc.....
Old Oct 26, 2003 | 10:31 PM
1990Fordf150v8
Hey Mike, Do you have AOL or Yahoo? I've got some questions for you since we have the same truck. Please get back to me.
Old Oct 26, 2003 | 10:32 PM
KeelarPluto
Yeah, I have AOL.....So I have AIM
Old Oct 26, 2003 | 10:34 PM
1990Fordf150v8
What's your AIM name? Mines fritolayguy2003
Old Oct 26, 2003 | 10:35 PM
KeelarPluto
Okay.....I just IM'd you
