Fuel lines
Old Feb 11, 2021 | 12:50 PM
Kevinskuce's Avatar
Kevinskuce
Fuel lines
Wondered if anyone can help with my query about the fuel line between the fuel tank (under bench seat) and the firewall flex hose. Looking at the tank, it looks like the tank take off drops out the bottom of the tank and runs forward to the firewall. If that is correct I’m concerned about bits in the tank always being sucked thru. Should there be an upstand Inside the tank?
Its been suggested for me to fit a good quality in line filter. Where is the best location?
Appreciate any guidance.
Old Feb 11, 2021 | 12:57 PM
Kevinskuce's Avatar
Kevinskuce
1945 half ton pick up
Thought it might help to say what the vehicle is!
Half Tom pick up. 1945.
Old Feb 11, 2021 | 03:12 PM
newold46's Avatar
newold46
It used a partial gravity feed to get it moving towards the engine. I've always seen the in line filter close to the carb where you can see inside (clear obviously) and change easily when needed.
Old Feb 12, 2021 | 01:50 AM
Kevinskuce's Avatar
Kevinskuce
Half ton pickup 1945
Thanks for the reply. I will just drop out the bottom of the tank and run forward slightly down hill before it turns up at firewall. The tank has been refurbished so no junk inside.
kevin
Old Feb 12, 2021 | 02:43 PM
f5fordgirl's Avatar
f5fordgirl
If using the orig type fuel pump, its got a very fine screen above the sediment bowl.
Old Feb 12, 2021 | 11:36 PM
Kevinskuce's Avatar
Kevinskuce
Yes it does have that and I’m keen not to restrict the fuel flow. If I fit a filter I will need to select carefully.
Old Feb 13, 2021 | 09:29 AM
tacomacream's Avatar
tacomacream
I use a paper filter in the fuel pump bowl.
Early_Ford_Store of CA - Early_Ford_Parts - New & Used Original Parts for 1928-1959 Cars & Trucks
Old Feb 14, 2021 | 02:52 AM
Kevinskuce's Avatar
Kevinskuce
Thanks I may try that...
kbx
Mar 11, 2016 01:03 PM
Holehawgg
Mar 20, 2014 09:21 PM
kidoo
Jun 23, 2006 04:49 PM
78crewcabjohn
May 10, 2006 06:02 PM
