96 E-350 front end shimmy
Old Oct 27, 2000 | 08:41 AM
plmbst's Avatar
plmbst
87,000 miles on my E-350 van, I'm experiencing a steering wheel shimmy when I apply the brakes. I had a slight shimmy previous to yesterday, however it's gotten worse since I installed new (Ford) pads, had the rotors cut, and re-packed and adjusted the front wheel bearings (yesterday). The front tires show wear on the inside of the treads.Are worn ball joints the usual suspect? Thanks for any thoughts.
Old Oct 27, 2000 | 10:40 AM
PAUL_2's Avatar
PAUL_2
If the tires are wearing more on the inside edge of the tread then the Toe is off . Its possible the Ball Joints are worn also . Best thing to do is have an alignment shop check the front end specs & to see if the ball joints need replacing .
Old Oct 28, 2000 | 05:10 PM
plmbst's Avatar
plmbst
It turns out that poorly cut rotors were the cause of my steering wheel shimmy/shudder. I took them back to machine shop and the tech re-cut them. Thanks for the response.
Old Oct 28, 2000 | 05:39 PM
hotrodford_88's Avatar
hotrodford_88
MDSuperDuty
Escape & Escape Hybrid
Sep 13, 2014 08:21 PM
DanK5
1997 - 2003 F150
Aug 4, 2011 10:43 PM
grndpndr2
6.7L Power Stroke Diesel
Oct 9, 2010 06:21 AM
Black Mack
Jul 24, 2003 09:11 AM
Highball
Jul 23, 2003 06:11 PM
