I have an e250 2007 handicap conversion van. rear ac installed with separate controls for the rear by the original conversion company. these trucks were sold empty with minimal add-ons specifically to be converted to ambulett's or handicap vehicles. Now I cant for the life of me find the low side ac fill port. I traced the line from the compressor to where the line splits to the accumulator then under the front cowling across to the drivers side then down and then runs to the rear. when the heck is it. its not on the accumulator
I can't make out too much detail with these photos but you'll need one more slightly to the left showing the hoses where they join the rear lines.
Its unlikely there'd be another service port under the van or towards the rear evaporator but double check anyway. The components showing from what I can see don't resemble the factory lines I removed and replaced when completely eliminating the OEM rear A/C & Heating unit.
