Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1970 C-750 Vin Decode
Old Feb 10, 2021 | 09:52 AM
JimboFT's Avatar
JimboFT
I just purchased a 1970 C-750 Grain Truck. I believe it has a 361ci v8. I am looking for help finding manuals, parts, etc. Any info on sites, forums, etc. would be most appreciated. Especially info on the braking systems. Everything on this truck works. 74k original miles and used fir farm work only. My challenge us filling the master brake cylinder and bleeding. Master cylinder looks totally different than I'm used to being as it's a cab over. Tia for any help/pointers
Old Feb 10, 2021 | 10:24 AM
85e150's Avatar
85e150
Welcome to FTE.
Those are filled from the top after you pull the boot back. I might be able to find an illustration later today. As for a manual, look at this:
https://www.hipoparts.com/1964-72-fo...ts-catalog-cd/
Old Feb 10, 2021 | 10:48 AM
JimboFT's Avatar
JimboFT
Need help with the following vin
Old Feb 10, 2021 | 03:46 PM
85e150's Avatar
85e150
C75 = C750
E = 361 2v FT gas V8
V = Kentucky Truck Plant
J21763 = 1970 numerical sequence
135 = 135 inch wheelbase
No color code, painted a non-standard color.
C750 = C750, 24,000lb GVWR
DB8 = I do not have upholstery info, but color, material and type of seat are indicated here. The combo also indicates Custom Cab w/o sleeper.
M = Clark model 285V 5 speed direct transmission
E1M
E1 = Rear axle code, I have to look for that. EDIT: From a 1980 model decode: E1 = Eaton model 16244 Two Speed Rear Axle / 5.57/7.75 / 17,500 lbs. Rear Axle Capacity
M = Ford 7,000lb capacity front axle with power steering
24000 = 24,000lbs GVWR
182 3800 = 182 certified net HP @ 3800 RPM
463369
46 = Indianapolis District Code
3369 = Special order number. Your engine, axle and transmission codes are present. Only the paint is missing, so the special order may (or may not) have been the paint and probably something else as well.
I'll get back on the axle. If something doesn't match your truck, let me know and I will double check.
edit:
Trying to double check that rear axle code. That code shows for several later trucks, gas and diesel, but I'm a little suspect as I don't have the MPC to confirm the info. As these axles go, that would be pretty tall compared to what Ford usually did for gas engines.
Old Feb 10, 2021 | 05:27 PM
85e150's Avatar
85e150
Post 3 and 4 here. Forget the links in 3, some are bad and others are the same info. Note the suggestion to use a squirt type oil can, and tilting the cab.
https://www.ford-trucks.com/forums/1...nder-fill.html
Old Feb 11, 2021 | 10:14 AM
JimboFT's Avatar
JimboFT
Thanks! Everything matches so far.
Old Feb 15, 2021 | 10:24 AM
SVO2SCJ's Avatar
SVO2SCJ
filling bleading
I too had to learn how this system worked ! The hipoparts.com manual helps for exploded views.
I found it easy to use a picnic mustard container to install a vacuum hose and INVERT to squeeze on the cylinder after removing the boot.
THE other thing I learned was REFILLING while doing the bleeding is important as I ran it dry and introduced more air (but didn't know).
MARK
P.S. you probably have the assist booster by the driveshaft at the rear of the truck.......after doing the wheel cylinders do that one too
mudguppy
Large Truck
Feb 19, 2021 08:37 AM
OrangeF600
Jan 27, 2021 05:50 PM
shrekga
Large Truck
Jan 1, 2021 06:20 PM
Jjkrause
Large Truck
Sep 12, 2020 09:08 PM
zsyves
Sep 29, 2019 05:33 PM
