Rough Idle Multiple codes
Old Mar 30, 2021 | 07:19 PM
  #31
acmectec2001's Avatar
acmectec2001
I will check those 2 sensors. I found a pin-out diagram online for the ECM connector and if I can trust it, it looks like everything is basically the same for the 4.9, 5.0, and 5.8 except for the number of injectors and a few wire color differences from 92-93.
Old Mar 31, 2021 | 08:15 AM
  #32
rla2005's Avatar
rla2005
The PCM connector is the same for V8 versus 6 cylinder engines. There will be differences for transmission as well as later model changes for Speed Density versus MAF. The place where things frequently change is connector C101.
C101 is a big connector located on the driver side inner fender.
And that's the one I do not have a pin-out diagram for. There may not be any differences between a V8 versus 4.9L engine for that connector, but then again...there might.Most likely given everything works you are fine.
Old Mar 31, 2021 | 10:11 PM
  #33
acmectec2001
I checked the 2 sensors. The CTS checked fine. Ended up at .64V and 2.62 K Ohms after engine was warm. The ACT is at 32.5 K Ohms at 68 deg. (within the 15%). With the engine warm it was at 1.4V and 5.3 K Ohms, however, I do not know the temp of the manifold. Both have 5 volt supply.
Old Mar 31, 2021 | 10:47 PM
  #34
acmectec2001
I haven't found the diagram for a F150/ I did find this. Its from a 94 Bronco. I know it could be different for a 92, but it appears all engines use same connector.
Old Apr 1, 2021 | 08:46 AM
  #35
rla2005's Avatar
rla2005
That's the caveat here. From year to year the circuit/function can move to different pins. A 1994 Bronco is most likely MAF and more than likely there are a few pins that have different functions assigned to them than a 1992.
The reason for my pessimism is this C101 diagram Subford posted in this thread: https://www.ford-trucks.com/forums/1...g-harness.html
There may be no issue with the pin-outs for C101 on your truck, it's just something else to keep in mind. Your ECT and ACT sensor values look reasonable.I would pull out the computer for an inspection as a next step. Also make note of the alpha-numerics on the computer. Specifically the Ford engineering number (example F4ZF-12A650-EA) and the programming code (example HOG0). Could be a mismatch for your engine.More info here: Fuel Injection Technical Library » EEC Program Codes
Old Apr 1, 2021 | 03:08 PM
  #36
acmectec2001
The program codes aren't on that list but the engineering # says it is from a 92 f150/ manual trans.
Old Apr 1, 2021 | 03:26 PM
  #37
rla2005's Avatar
rla2005
A little surprised it is giving you 3 digit codes. What did the inside look like?
Old Apr 1, 2021 | 04:00 PM
  #38
acmectec2001
Haven't got it out yet. Pulled it out enough to get the number. Going to pull it later tonight.
Old Apr 1, 2021 | 04:21 PM
  #39
rla2005's Avatar
rla2005
I use a cut off broom stick to pry down on the plastic inner fender a bit for clearance to slide out the computer easier.
Old Apr 1, 2021 | 08:16 PM
  #40
acmectec2001
Well hopefully, this is the problem. My luck, this just controls the brightness of the dome light!
Old Apr 2, 2021 | 07:03 AM
  #41
rla2005's Avatar
rla2005
That is definitely not helping you at all.
F250AZ
Nov 18, 2015 01:36 PM
hawgystyle
Feb 1, 2010 09:13 PM
laserred
Feb 2, 2006 09:36 PM
Red Raider 4x4
Apr 13, 2003 12:16 AM
dakota
Aug 22, 2002 02:26 PM
