Help! Intermittent Non-Start! Cause?
Old Oct 26, 2003 | 03:22 PM
schindelbeck's Avatar
schindelbeck
Angry Help! Intermittent Non-Start! Cause?
This problem just popped up suddenly today on my 1997 Expedition 5.4 EB-4. You put the key in the ignition and turn it and absolutely nothing happens, as if the trans is not in Park (but it is). Then sometimes if you really hold the ignition/key turned for 3 or more seconds, it will suddenly start turning over!
What is the problem? Seems to be independent of key so I don't think it's the anti-theft. Seems more like just a bad ignition switch. Does anyone out there know what this likely is before I take it to the dealer and assume The Position? Thanks!!
Old Oct 26, 2003 | 05:03 PM
Jwalence's Avatar
Jwalence
Loose or dirty battery cables or starter cables.
Old Oct 26, 2003 | 06:11 PM
rangedog's Avatar
rangedog
My 97 may have the same problem. It appears to be in PARK but it is not completely. By holding the shift lever in Park and turning the key it will start.
