7.3 gas engine swap
Old Feb 7, 2021 | 07:39 AM
Rolandcad500's Avatar
Rolandcad500
7.3 gas engine swap
Hi Guys and Gals.
I have been wondering about doing a timung job. But feel quite intimidated by the posts others have put up. Plus it seems we are sort of fighting with a difficult engine to start with.
I bought the truck to last. As ive been told lots about Fords are good. Most guys i know swear by ford trucks.I have a couple of other earlier ford trucks. So thought with the budget i had i had done the right thing.
while i was thinking about the timing and the work needed to do it. Or maybe get a reman. Ok. So a reman is gunna be good for 100k or more. I dont drive mad. But do like power when its needed for either easier towing or overtaking. Been having a little read up. It seems the 2019 7.3 gas engine will bolt uo to our gearbox pattern. Yhey reckon its pretty bulletproof and more basic engine to work on.
This vould possibly be a completely mad idea. But you can get a crate engine for about 8k plus taxes.
Has anyone done one yet? Have any thoughts on this option.
Thanks Roland
Old Feb 7, 2021 | 08:37 AM
WWR's Avatar
WWR
Originally Posted by Rolandcad500
Hi Guys and Gals.
Thanks Roland
If replacing stock for stock in an existing system intimidates you, i wouldn't undertake a custom engine swap.
No matter how easy the interweb might make it sound, engine swaps will nickel and dime you with little things the write-ups (if they existed) fail to mention. You'll be thrown curve ***** on fuel lines, power steering hoses, steering box clearance, getting gauges to work, etc etc (all only examples in general of engine swaps).
If you can think on your feet, have extra EXTRA time for the truck to be down, have extra budget for the unforseen, are good at improvising and diagnosing electrical, go for it. It'd be a cool swap but it won't be a weekend project and the $8k for the crate engine is just enough to get you into trouble and keep you committed 'cause it'll be too late to turn back after that.
I also wouldn't put the 7.3 gasser behind the 4R70/5 or an 8.8 or 9.75, so plan on at least a trans swap. I guess you could run your rear axle 'til it grenades
Old Feb 7, 2021 | 09:04 AM
Rolandcad500
Ah. Thats true. I hadnt quite put down. Ive built a few hotrods. Enjoy the problem solving. Fabrication work. General improvement.
With most things. I buy the best i can afford. But do like older style of vehicles. But needed something to be super strong and dependable.
Like your thoughts re transmission though. 10speed would be great.
Thanks for the input its appreciated.
DALEDIESEL
Aug 10, 2020 08:29 AM
bocomojoe
Large Truck
Sep 12, 2019 04:08 PM
Galaxie mike
Apr 11, 2016 09:24 PM
ProjectDually
Kansas Chapter
Jan 19, 2015 07:54 PM
IDI guy
Jan 22, 2012 04:49 PM
