How to fix this dent?
Old Feb 5, 2021 | 02:30 PM
jackietreehorn's Avatar
jackietreehorn
I can’t stand looking at this any longer but can’t justify the expense of a bodyshop, especially because this is a work truck.
One of the guys did this to the bed quarter backing into a dumpster. Doesn’t look to bad from 50 feet away.
I am interested in improving this myself without a full blown repaint.
can somebody recommend a method and which tools to fix this? I know next to nothing about the fine art of body repair.
Old Feb 5, 2021 | 05:18 PM
sandymane's Avatar
sandymane
I just went through something similar. I pulled the front tire off and leaned it against the driver door resting against the black trim. While working on the front end, I had to jack the truck up higher and adjust the jack stands. This caused the top of the tire to slide under the black trim. When finished , I tried lowering the jack to get the hub lower to install the tire. This caused.the tire to dig into the door and created a big dent. I used fishing line to remove the trim. The aluminum trim in the trim straighten out nice. Next I cleaned the old sealant from the door and the trim piece. Then I used a plumber plunger to pull the big dent out. I used 3M two sided tape on the trim piece and installed it. Cleaned everything up and it turned out good. You can see a slight line if you look down the side of the truck but not from any other angle. I had nothing to lose at this point. It might work for you. Sandy
Old Feb 5, 2021 | 05:56 PM
jackietreehorn
Plumber's plunger! Are you for real? I gotta give that a try. I was thinking some giant ACME magnet might work.
Old Feb 5, 2021 | 06:46 PM
spurredon's Avatar
spurredon
If that is a sharp dent toward the front of the box you may need a hammer and dolly. There are a lot of know- it- all's on you tube that tell how to do this stuff, entertaining at any rate! Some know there stuff. Try "paintless dent remover"
Old Feb 5, 2021 | 07:02 PM
GNR22's Avatar
GNR22
I've popped out some bigger dents and stuff with a porta-power. If it's smooth enough that you can get a plunger to stick, that also works well.
Old Feb 5, 2021 | 07:20 PM
torq'ta 5 8's Avatar
torq'ta 5 8
The warmer, the metal is, the easier it will move, paintless dents guys, come to parking lot at work, and ask that you park dent side to sun, they have metal, and wood rollers, they use when possible.
Old Feb 5, 2021 | 07:35 PM
jackietreehorn
Ok sounds like this be an April project at the earliest. When its hot, I will try a plunger then magnet. Failing that, I will try to pry it from inside and behind.
Old Feb 5, 2021 | 09:24 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Never use the ACME magnet. Just ask the coyote!
Old Feb 6, 2021 | 06:08 AM
tjc transport's Avatar
tjc transport
i ain't rite
if you are talking about the crease between the body lines, a plunger or suction cup will not work for that. and do not pry behind it, you will only do more damage than what you have.
you are going to have to tap it out with a hammer on one side, and a dolly on the other.
once it is tapped out, you can reform the metal with the heat shrink method.
Old Feb 6, 2021 | 06:14 AM
My4Fordtrucks's Avatar
My4Fordtrucks
79F250isalive!
36
Jun 29, 2015 09:41 PM
Bohman731
Aug 27, 2014 07:45 PM
shop.keeper
Sep 15, 2010 03:36 AM
rmalottwtes30
18
Jun 20, 2008 11:49 AM
mudder460
Arkansas Chapter
15
Mar 3, 2008 07:16 AM
