Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1978 F700 Decode
Old Jan 10, 2021 | 10:27 PM
Cole_broadbent's Avatar
Cole_broadbent
1978 F700 Decode
-----------other truck decode removed------
do you have a decoding chart that you can compare the numbers to that tell you all of the different info? Some of my info is the same but I have a different tranny and a couple other things that I wanted to find out. If you could post a picture or link to the chart it would be greatly appreciated.
thanks,
cole
Last edited by 85e150; Feb 3, 2021 at 04:32 PM. Reason: remove other decode for clarity
Old Jan 10, 2021 | 10:32 PM
85e150's Avatar
85e150
Welcome to FTE!
It's not a chart, it's the Master Parts Catalog for the appropriate model years.
If you want to post your info, post a picture of the whole warranty plate and I will try to look it up for you.
Numberdummy is here much less frequently now.
Old Feb 3, 2021 | 12:23 PM
Cole_broadbent
Warranty plate
Originally Posted by 85e150
Welcome to FTE!
Hopefully you can read this. What do I use in the tranny? 80w-90, 85w-90, 50wt (if it is 50w, is it a gear oil or engine oil?). What about the rear end? The small gear box for the 2 speed I have heard is 10wt, is that a gear/hydraulic type oil or engine type of oil? Any idea on the oil type for pto gear box and hydraulic for dump hoist?
thanks a lot
Cole
Old Feb 3, 2021 | 04:34 PM
85e150's Avatar
85e150
Your truck deserves it's own thread.
F70 = F700 gas
E = 361 4V XD FT gas V8. ("eXtra Duty", same as "Heavy Duty" in this case)
V = Kentucky Truck Plant
BB3413 = 1978 numerical series
146 = 146 inch wheelbase
3 = Dark Red Metallic
F703 = F700 gas, 23,000lbs GVWR
4A8 = Standard cab. Upholstery can be determined from this, but I don't have that info.
J = This is usually the auxillary transmission code. In this case it indicates "Calif. emissions less fan clutch"
2 = Clark model 282V 5 speed direct transmission
E3M
E3 = Eaton model 16244 rear axle, 17,500lbs capacity, 2 speed, ratios 6.50/9.04
M = Ford 7,000lb capacity front axle with power steering. (also a 12,000lb axle w/o ps. Do you have ps?)
23000 = 23,000lbs GVWR
231183
23 = Memphis District Code
1183 = Special order number.
Odd that it was a Memphis District Code but has a Calif emissions code.
If anything seems incorrect, please let me know.
Old Feb 3, 2021 | 05:12 PM
85e150's Avatar
85e150
Oil for your Clark:
https://www.eprogear.com/eaton-clark...ce-manual.html
80w-90, GL5. BUT NOT LABLED EXTREME PRESSURE
If you are in doubt, use a GL4 oil. Serving suggestion.
Old Feb 3, 2021 | 11:04 PM
Cole_broadbent
Decode question/reply
F70 = F700 gas
4A8 = Standard cab. Upholstrey can be determined from this, but I don't have that info.
E3M
231183
weird it says dark metallic red. It’s yellow inside and under the hood with white that’s coming off over the rest of the body. Has a hertz rental badge on the inside of door next to the warranty plate that I posted the picture of but I don’t think that it can be seen so that’s why I assume that was the original color and the whole thing wasn’t repainted at one time. Yes, I have power steering (I probably wouldn’t have it if didn’t). What does a fan clutch have to do with emissions? What does the special order number mean?
thanks a lot for your time and effort to do this for me.
Old Feb 3, 2021 | 11:07 PM
Cole_broadbent
Oil question
Oil for your Clark:
what is the difference between GL5 and GL4? What is bad about GL5 extreme pressure? Any special GL4 to use/watch out for? I’ve heard about gear oil that can be bad for yellow metals like brass, is that what the reason is?
Old Feb 3, 2021 | 11:16 PM
85e150's Avatar
85e150
GL5 extreme pressure is bad for the synchros, and that link mentions it. However it does recommend GL5. Usually all GL5 is said to be bad for synchros. Thus I suggest find GL4. The difference? Well, this says it's all in the extreme pressure additives, and that all GL5 has them.
https://www.rymax-lubricants.com/upd...gl-4-and-gl-5/
Not sure why Eaton recommends GL5 then tells you to avoid EP additives. One of lifes mysteries. Run GL4.
Old Feb 3, 2021 | 11:24 PM
85e150's Avatar
85e150
Regarding the paint code. I rechecked it. That's what the catalog says. USUALLY with a Hertz or other company with their own colors, the color code is blank, and the color is a non-standard color. If Hertz did their own repainting, red would be an odd color to start with. At some point, Ford made white the stadard color, and everything else was special order. I don't know when that happened or what it actually meant to the medium truck customer.
As to Calif. emission and a fan clutch, beats me. Maybe Hertz registered this truck in CA, or maybe the intentionally sought to eliminate the fan clutch on rentals.
Special Order number--I do not have info on that. As with color, a special engine, trans or axle usually results in a blank in those spaces on the tag, and then the other components are added after Ford is done with it.
Double check everything you can. It is not unusual for doors to be changed and the old warranty tag left in place. Does the VIN on that tag match your title?
Old Feb 4, 2021 | 09:58 AM
cwegga's Avatar
cwegga
Yes, that is the reason. I'm not an expert on the particular equipment you have in your truck. But in my youth I had a very expensive trip to a quick lube place when I had them refill everything before driving off to college in my Nissan truck. They must have used GL5 instead of GL4 like was called out in my owners manual and in a little bit, I was dead on the side of the road, had to tow my truck hundreds of miles home and spent some of my summer swapping an expensive transmission in the dirt in my yard. Be careful to use the right stuff that won't damage your hardware.
LinwoodP350
Aug 9, 2016 11:17 PM
Jolly Roger Joe
32
Aug 6, 2016 02:40 PM
Corner Gas
Nov 24, 2007 06:19 PM
brosko80
Feb 18, 2006 10:10 PM
pdqford
Oil & Lubrication
Jun 12, 2004 03:00 PM
