79 Frame v.s. 88 Frame.
Old Feb 1, 2021 | 07:44 PM
NP79's Avatar
NP79
Exclamation 79 Frame v.s. 88 Frame.
If I was looking to swap a 1979 f150 single cab short bed on to a 1988 f150 single cab short bed frame what differences would I see. Is it possible? are they the same? are they just not compatible?
Old Feb 1, 2021 | 11:27 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
This and a tape measure is a place to start. Yes this is a long bed...but get you going in the right direction.
Old Feb 2, 2021 | 06:46 AM
speedfreak78's Avatar
speedfreak78
From what I've seen the frames on the 80-97 trucks are similar enough from the transmission crossmember back that a lot of stuff is a direct swap. The front of the frames are different, depending on what front suspension it had, 2wd vs 4wd, solid axle vs TTB, etc. A body swap shouldn't be all that difficult, but you might have to move the frame side body mount perches to line up with the old cab.
Chaosracing
2004 - 2008 F150
Jan 9, 2018 10:43 AM
4x484150
Ford Truck Parts for Sale
Jul 31, 2015 02:26 PM
FLICK
Mar 29, 2005 10:34 PM
dino360
Paint & Bodywork
Jan 14, 2005 07:07 PM
