Motor is at tdc
on
180 deg off maybe.
Cyl #1 is passenger side front.
Remove the spark plug and and rotate the motor with a breaker bar until the piston comes up to TDC on the compression stroke, air will be pushed out the plug hole when this happens.
Use a piece of rigid wire or a small straw placed down the plug hole to feel for exact TDC.
Now check the crank pointer, is it lined up on the 0 mark?
If so you're good, if not the timing set isn't installed correctly or the balancer outer ring has slipped.
I_Love_Cheese
07-31-2007 07:51 AM
muddingmcdude
17
09-02-2006 09:00 AM
