Sponsored by: Real Truck
Need power for plow control
Old Jan 30, 2021 | 05:19 PM
scottymacc's Avatar
scottymacc
Have an 02 ccsb with v10 4*4. Installing a Hiniker 8.5 ft plow and need to know what wire under dash has power when key is turned on for use with control.
Old Jan 30, 2021 | 10:29 PM
blakeusa's Avatar
blakeusa
Power is normally routed from the battery - to a solenoid that then travels to the in cab control.
On 2002 Super Dutys there is 12V post under the hood near the brake fluid reservoir.
Old Jan 31, 2021 | 03:42 AM
scottymacc's Avatar
scottymacc
Ive got the main harness under hood connected to battery. I need a keyed power wire under dash to power the plow control relay in the handheld controller. You know turn key then power instead of full power to system all the time
Old Feb 1, 2021 | 11:50 AM
Ace_boy2786's Avatar
Ace_boy2786
In my 05 Diesel there was a bundle of "Blunt-cut" wires behind the 4x4 switch area, i forget what the tag said, I believe something along the lines of "Customer access" similar to the ones behind the fuse panel. there's a White/Blue (iirc) wire that is an ignition wire; I don't know the fuse rating or your requirements for the control head and make sure you test for the correct wire. Otherwise you can tap into the ignition harness and get an ignition wire from there. look up a remote start wire guide for your truck for the color wire needed (again test to verify). I use the12volt.com for stuff like that.
Jayybird
6.7L Power Stroke Diesel
May 12, 2023 03:43 PM
FSRBIKER
Dec 13, 2017 04:40 PM
RRRAVEN
Jan 3, 2014 09:47 AM
moonunit7317
Nov 27, 2007 06:24 PM
74F250
Oct 2, 2003 09:20 PM
