Salter & Plow controller locations
I had an 8'2" Boss V plow in my Ram. I used the hand-held control pendant so no permanent mounting was required. I used a strip of velcro thru the hand loop and around my right thigh to hold it in place while plowing. I found that to be very convenient, although I rarely needed to exit the cab while plowing.
If you have the outfitters switches, wouldn't one of them work for the salter control, providing it only requires an on/off switch?
Looking at the pictures online it looks like I can unplug the controller from the pigtail. I might just ask to have the dealer leave me enough wire hanging from under the dash and mount it to an adjustable cell phone type mount. Maybe something like this https://smile.amazon.com/dp/B071P2LK...ing=UTF8&psc=1
Cubby is too small for that box and seeing it and reaching wont be ideal. Could you mount into a bracket that is attached to a cup that sits in the front cup holder so its up on a stand ? then you can take out in summer. I would have one cup holder filled for the plow (in front, and back could be for sander. Slide the cover over and you still have two cup holders available. A simple block of wood shaped like a cup and painted black with a mount to it would work....
thewholetruth
2017+ Super Duty
13
04-27-2020 06:24 PM
Ruffasacob
02-15-2016 06:13 AM
Welsch69
01-27-2011 05:00 AM
mando jake
11-02-2010 11:20 AM
