13 speed is air operated if you didn't know. You would need to add a compressor and an air tank if the engine does not have one.
The easy thing to do is to buy an old school bus with a T444/T444E and a 5 or 6 speed. Many of them will have a Spicer 5spd... This works because the T444E is basically the 7.3L powerstroke. There are differences but you'll be able to fit it. The medium duty trans will fit with little work,
the 3 or 4 cylinder cat diesels are WAY too small for powering a pickup.
the 1.5L 3 cylinder is only 40 HP.
the 4 cylinder 4.4L has a max HP rating of only around 140 HP
Im hoping the cat engine has a chain driven compressor already on it.
My pick up was on a dyno last week and its only putting out 130hp with the 302 small block. I have a 8cyl in my pete pushing 600hp. So im not sure what size will fit in place of the 302 with out making too many frame and body modifications
the problem with this is pretty much any diesel you find is going to weigh at least twice as much as that 302.
so nothing is going to be a drop in without frame and suspension modifications.
Cool. That is sweet. The last one I had was an ‘04 KW, C15 CAT, 18 sp. 625 HP. Straight truck w/ body tank pulling a 4 axle 28 ft pup. Generally grossing around 110,000.
