LOL well crap!
Old Jan 30, 2021 | 07:52 AM
Listor's Avatar
Listor
LOL well crap!
Just went out to grab the paper, bent down and looked left , something caught my eye!
Grabbed a flashlight , good size oil spot on the driveway backside of the engine!
2002 CCLB 4x4 Gonna rename her to Money Pit!
Old Jan 30, 2021 | 08:04 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
You could sell it and get a 6.7L for the cheap price of $1000 a month...
Or...
You could wait for GM to go all electric by 2035... That will be GREAT!!!
Old Jan 30, 2021 | 08:41 AM
Listor's Avatar
Listor
Or...
LMAO or put a couple of bucks into a paid off vehicle , You can do better then that HOBO !
Old Jan 30, 2021 | 08:47 AM
RA101725's Avatar
RA101725
Banned
Oil cooler? It’s leaky seal season
Old Jan 30, 2021 | 08:49 AM
FordTruckNoob's Avatar
FordTruckNoob
Are you sure it's not somebody doing this to you?
Old Jan 30, 2021 | 08:54 AM
Listor's Avatar
Listor
just did the oil cooler, it's dry, It was the 1st thing i thought of! But this is leaking at the dust cover, so likely turbo pedestal, but will investigate as it warms up a little!
Old Jan 30, 2021 | 08:56 AM
Listor's Avatar
Listor
https://youtu.be/LONT1oboJrs
LMAO it could be, but i doubt it! I would have to wring someone's neck for it !
Old Jan 30, 2021 | 09:00 AM
RA101725's Avatar
RA101725
Banned
Pedestal o-rings would be my next guess. The ones between the turbo and pedestal you should be able to see a leak. The bottom ones between the pedestal and block no.
Old Jan 30, 2021 | 09:12 AM
FordTruckNoob
If that's the case, this thread may be of interest.
Old Jan 30, 2021 | 09:14 AM
Sous's Avatar
Sous
FTE Emeritus
Check your HPOP line fittings on the heads. The passenger side of mine was oozing and running down to the plenum cover, then toward the back of the engine and down the drain in the valley. I thought it was a pedestal o-ring for months and put off fixing it. I finally bought a scope camera and saw the pedestal was dry, then I saw the oil oozing out of the HPOP head fitting. 1/8 a turn and it has been good to go for months.
Check the easy stuff first, sometimes you get lucky.
Old Jan 30, 2021 | 09:47 AM
Listor's Avatar
Listor
I agree with that 100%
Old Jan 30, 2021 | 10:05 AM
Listor's Avatar
Listor
I did forget , my gp relay took a crap, i know there is a better unit out there, point me in the right direction please!
Old Jan 30, 2021 | 10:22 AM
Sous's Avatar
Sous
FTE Emeritus
The White Rogers/Stancor unit from Diesel-O-Rings has been a tried and true replacement, but it is oversized and requires a bit of "massaging" to fit right.
Recently, KubotaOrange76 identified an upgraded GPR that is the same size as the OEM GPR. It is the Trombetta 684-1241-212.
Old Jan 30, 2021 | 10:40 AM
Listor's Avatar
Listor
Thank you for the glow plug relay information I will check it out when I get home got under the truck looking for the leak turns out that my golden nugget is leaking with the Allen wrench to tighten it up tomorrow when I have more time I will take it apart and re-seal it properly
Old Jan 30, 2021 | 01:30 PM
RA101725's Avatar
RA101725
Banned
I think the one CNC Fabrication sells is a good one for cheap and sits like the stocker does. (Western Snowplow?)
The Stancor/White-Rodgers sits sideways and is a little awkward to get in there and hook up. I’d try the other one. Drop the negatives off the batteries of course.
edit: never mind, the one CNC sells is the Trombetta.
